Hi and welcome to FixYa, I am Kelly
First off this a a great parts diagram on one page:
http://jandwtools.com/index.php?l=product_list&c=1066
This is pretty much the same generator as the Robin R-6100. If you look on the data plates you will see that is was made by Fuji Heavy Industries Ltd. (I.e. Subaru)
Here is the complete Parts list in pdf format:
http://www.ereplacementparts.com/images/Makita/G6100R.pdf
Open the control panel by removing ONLY the outside face panel screws. The whole panel will tip out.
- Check the yellow wires of the condensor (capacitors) They go into the fubber flex interconnect tube between the control panel and the power head. The wires have quick disconnect connectors. Check the connectors for signs of heat. I have had to cut these connectors off on several units and solder the wires together. I use heat shrink tubing over the repair that must but placed on the wire before you solder and slid down far enough it does not shrink when you repair the wires.
-*-With the wires disconnected from the condenser, measure the resistance of the yellow wires on the power head side. It forms a winding loop.
- Look at the capacitors...(Item 75 on the diagram) they are notorious for leaking wax and the bottom of the control panel enclosure will have wax on it if the capacitors have leaked. My experience with these capacitors is that the wax filled ones do not handle the heat well. I now replace them with oil filled caps and they do not have the same leaking wax failures from heat. Also... instead of buying the whole condenser assembly for about $150.00 you can just replace the capacitors and save yourself some money!
I have to post again as I am runing out of time here to post this. Next post will be a service manual type link.
Thanks for choosing FixYa,
Kelly
