20 Most Recent Honda 3000 Watt Portable Generator Questions & Answers
3answers
Why does my generator pulsate while running, what's wrong with it?
This action is called governor hunting which generally means the carburetor needs resetting ,a complete internal cleaning or a rebuild then adjust the high speed and low speed settings by the adjusting screws on the governor spring system (manual may be required for these settings)
8/11/2019 1:50:18 PM • Honda 3000 Watt ... • Answered on Aug 11, 2019
Oil leaking out my honda 3000is generator.
In the process of using diesel generator set, soft rubber pipe is easy to rub with the parts around it, and it is easy to wear and tear oil leakage in the long run. However, most of the fuel supply system of diesel generator set uses soft rubber tube, so it is not easy to find the oil leakage point. Below are instructions provided by Starlight Power small make up to teach you a few diesel generator unit pipeline leak spot check method. Method one: exhaust the air from the diesel generator unit, then start the unit to find out the leak point. Method two: release the gas screw of the unit injection pump and release the oil from the hand oil pump. If it is found that the discharge screw starts to discharge a large amount of bubble oil, and the bubble still does not disappear after the repeated hand pump, it can be determined that there is a leak point in the low pressure oil pipeline from the oil tank to the oil pump section. The pipeline should be removed, pressure gas and placed in water, to find out where the bubble is the leak point.
11/21/2018 3:34:27 AM • Honda 3000 Watt ... • Answered on Nov 21, 2018
3answers
My 3000 watt honda generator doesn't seem to put out the proper power
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31ZT7601.pdf I would check spark arrester and clean it and the muffler first.lt could be the inverter unit. If you have a meter determine the output voltage, and freq. You would need a scope to look at waveform the repair should be lest to a repair center. suggest you call Honda for more guidance. You could spend a lot of money on maybe parts./
3/6/2018 2:35:31 AM • Honda 3000 Watt ... • Answered on Mar 06, 2018
2answers
Why is my generator is shutting down and running roughly
Hi there dirty plugs or fuel system
3/6/2018 2:30:04 AM • Honda 3000 Watt ... • Answered on Mar 06, 2018
Why ex 3000s does not produce electricity
Residual magnetism of the rotor out. Lift one brush off the slip rings and flash a 12 volt battery on the rings. Reconnect brushes and start engine no output? Repeat then seek help as I need to put my grippers on it to check
2/7/2018 6:43:20 PM • Honda 3000 Watt ... • Answered on Feb 07, 2018
What is spark plug gap setting for Honda 3000 watt portable Generator ?
Normally 25 thou
2/7/2018 6:38:19 PM • Honda 3000 Watt ... • Answered on Feb 07, 2018
I have a very old honda generator 2.8 KVA max
hi insure the wires from the magneto are not cracked or shaved as this would discharge to earth and the ht lead from the magneto to the plug is not perished as this would create leakage to earth
1/13/2018 3:22:11 PM • Honda 3000 Watt ... • Answered on Jan 13, 2018
3answers
Can I run synthetic oil in my 3000watt Honda gen
Of course you can, just use the correct weight.
11/16/2016 7:22:40 AM • Honda 3000 Watt ... • Answered on Nov 16, 2016
It starts and runs fine If you shut it off you hav to wait about 30 mis before it will start back up
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/ Generator Guru
9/25/2015 11:03:50 AM • Honda 3000 Watt ... • Answered on Sep 25, 2015
EM 3500 Will start, then stalls after 30 minutes, starts again and continues to staff after 5 to 10 minutes. Oil is fine.
With regrets, I do not have any personal experience with generator troubleshooting. However, I have been informed by some people that have good experience with them that a generator needs to be run for a couple of hours every month to keep the system in proper order. Should a generator sit idle for ten months, the fuel can actually "shellac" inside the carburetor and lines. This will then travel to areas that will gum up - thus the necessity to drain the tank and carburetor completely. Here is their advice: http://powerequipment.honda.ca/parts-service/storage-tipsYour service person(s) may not be aware of the time the unit sits idle, and if they are aware - then they are not giving you straight facts (in my opinion). I would suggest contacting Honda customer service directly, and explain this situation to them - they will probably be more then happy to have a technician assist you properly. Contact the 'customer relations' number, and they will direct you from there. Here is the link:http://honda.ca/contact_usI am sorry I couldn't be of more help.
9/1/2015 1:28:44 AM • Honda 3000 Watt ... • Answered on Sep 01, 2015
My trusty old honda 3000 is generator keeps on stalling out but always starts up immediately again could it be that it has been running three days long noe and overheating?
THERE COULD BE SEVERAL CAUSES; THE VOLTAGE REGULATOR, THE CARBURETOR, THE OIL LEVEL. ALL NEED TO BE CHECKED.
6/18/2015 1:26:28 AM • Honda 3000 Watt ... • Answered on Jun 18, 2015
MY HONDA 3000 IS GENERATOR KEEPS STALLING OUT, BUT IT ALWAYS STARTS UP IMMEDIATELY FOR ME, COULD IT BE OVERHEATING?
No, as with most small equipment engines, the culprit is the carburetor. You'll need to soak it in carb cleaner overnight in a sea;ed container and install the rebuilt kit for it.
6/16/2015 3:15:31 PM • Honda 3000 Watt ... • Answered on Jun 16, 2015
2answers
WHERE CAN i GET THE SPRING FOR THE PULL START ON ETQ 3000 GENERATOR
Never heard of an etq Honda generator,if is a Honda generator any Honda dealer should be able to help you. If its a Honda knock off ,some Honda springs will work.
4/13/2015 7:37:31 PM • Honda 3000 Watt ... • Answered on Apr 13, 2015
I got a stuck intake valve on a eu 3000 honda
how to reset the valves on a honda 3000 generator
12/13/2014 5:15:27 PM • Honda 3000 Watt ... • Answered on Dec 13, 2014
What causes blow back out of the carburater?
Make sure that the exhaust is not clogged.
12/5/2014 2:43:11 PM • Honda 3000 Watt ... • Answered on Dec 05, 2014
4answers
Need a battery for honda eu3000is
New battery for Honda eu3000is can be found on amazon. take a look here Charge your devices with guaranteed safety and chose the best one. P.S. watch out on seller reviews. I hope this was helpful. cheers
11/25/2014 10:25:56 PM • Honda 3000 Watt ... • Answered on Nov 25, 2014
2answers
Start the engine
I assume you refer to a 6500 watt Honda, if it's electric start/and manual(pull cord) First supply a 12 volt battery /if you haven't put fresh gas in it do the best you can to remove all the old gas from the tank and you should find drain screws and small hoses on the lower part of the carburetor. After completing this step add about 1 gallon or so of fresh gas, remove the air filter system from the face of the carburetor ,with a small squirt bottle put a tea spoon or so of gas into the of the carb, close the choke and turn the key, if it fires let it run with the choke closed for only a few seconds then slowly open the choke fully, if the engine stalls close the choke and start the engine again do not leave the choke closed for extended periods as this will cause engine flooding and spark plug failure. Also be sure you have inspected the existing spark plug to be sure it's clean if there is any question about the plug change it. BR
10/22/2014 3:03:19 AM • Honda 3000 Watt ... • Answered on Oct 22, 2014
How do I cross reference a discontinued part to see if an upgrade is available
On a honda part, I would check with Honda directly. Their customer relations folks are good to deal with:Customer RelationsTel: 770-497-6400Fax: 678-339-2519Mon. - Fri. 8:30 - 7:00 EST I did find that part on EBay for sale. I have to admit, I don't recall seeing that part on a Honda eu3000.
9/25/2014 1:49:18 PM • Honda 3000 Watt ... • Answered on Sep 25, 2014
Honda 3000 Watt  Portable Generator Logo
182 questions posted
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
run synthetic oil in 3000watt honda gen
  • Electrical Supplies
