Computers & Internet Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I start my computer I get the message PXE E61 Media Test Failure:check cable. Please, help me.
Anonymous
Level 2:
Sergeant:
  • Expert 179 Answers
  • Posted on Aug 18, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
179
Questions
Helped
32417
Points
568
Make sure first boot device is NOT set to network in the bios or maybe the hdd has gone and its looking for a operatin system to load Check cable connections (reseat),
Check jumpers on hard drive for Master/Slave or CS settings,
Check BIOS settings for boot order,
And lastly have your BIOS rescan your HD or reset your BIOS to defaults.
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
1helpful
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
2answers
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
PXE-E61 Media test failure
See this on-line thread from other users. I'd be leary about the posts that advocated hitting the laptop...
http://www.nocrash.com/ncbbs/msgs/3247.shtml
Portable computers can suffer from bad connections easily, so the first thing you should check are that all cables and other connections are tight and seated firmly.
2helpful
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
3helpful
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
15helpful
7answers
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
14helpful
7answers
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
15helpful
3answers
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
2answers
Trying to start my computer
you have a failed hard drive and will require a replacement.
Grand Canyon Tech
Grand Canyon Tech
