20 Most Recent Toshiba Satellite P25-S5263 Notebook Questions & Answers
Toshiba satellite m-45-s165 beep codes
Two beeps usually means a parity memory failure, but it changes form bios to bios. Here's what I suggest.... Toshiba Technical support is free for all owners of Toshiba computers and laptops for life, even if you bought the laptop second hand. I don't know where you are in the world but go to the Toshiba website and look up your technical support phone line and give them a call.
3/12/2015 11:24:09 AM • Toshiba... • Answered on Mar 12, 2015
Accidentally pressed multiple keys on the keyboard
Right Click the Mouse with your pointer on the screen
Click on Properties
You shall see a display window
Click on Settings
Screen Resolution... Slid to the Less Pixels
Click Apply Button
That should solve your problem
Regards
Salim
8/30/2013 7:33:28 PM • Toshiba... • Answered on Aug 30, 2013
2answers
Boots up windows runs for 5 mins then system shuts
You may have a cooling problem (with older computers), if you hear your fan running excessively and then it shuts down on you. Otherwise it is more likely a hard drive issue.
11/27/2011 3:14:18 PM • Toshiba... • Answered on Nov 27, 2011
Speakers sound "cracked", not much volume. Specs
reinstall the audio driver then restart the computer. you can download the latest audio driver from your computer manufacturer's web site.
6/11/2010 1:09:49 PM • Toshiba... • Answered on Jun 11, 2010
Satellite P25-S5263 PC Notebook: KEYBOARD NOT WORK...
It is better to give it for repair. But I would recommend using a USB keyboard externally. It is easier.Read more at www.fixpcfreeze.com
5/6/2010 5:44:22 PM • Toshiba... • Answered on May 06, 2010
Can i change my video memory on Toshiba Satellite
no, you have to change your video card
3/7/2010 10:49:16 PM • Toshiba... • Answered on Mar 07, 2010
Black screen
hello, those beeps you hear usually means some error, and it depends on how many beeps you hear and in which sequence. below you will find several BIOS vendors and their beep codes which help you detect the problem:
http://www.chem.pitt.edu/facilities/bios_beep_codes_list_v3.pdf
hope this help let me know if you need further assistance.
good luck,
regards,
Amar Sondhi
12/7/2009 4:58:22 PM • Toshiba... • Answered on Dec 07, 2009
Toshiba Satellite p25-s5263 boot lockup when wireless switch on.
Try to download and install newest windows drivers for the wireless and check BIOS for wireless settings. Apart from that... stick to Linux? ; )
11/9/2009 12:20:26 PM • Toshiba... • Answered on Nov 09, 2009
2answers
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
4/18/2009 10:28:21 PM • Toshiba... • Answered on Apr 18, 2009
Was upgrading the bios on
Re=install.
4/13/2009 4:11:17 AM • Toshiba... • Answered on Apr 13, 2009
Toshiba Satellite P25-S5263 Bios reset
remove the cmos battery from the motherboard for 30 seconds.It works i just did it on the a105-s4547 model
3/23/2009 2:36:37 PM • Toshiba... • Answered on Mar 23, 2009
Toshiba satellite p25-s5263 black screen
i guess your laptop's display chip is not working.
check it with the other one..
thanks
12/22/2008 7:11:56 PM • Toshiba... • Answered on Dec 22, 2008
Nothing comes on my screen when i power on
you have to resit the ram,if the problem is not solved then dislplay adapter is gone, you have to send it for repair
5/31/2008 9:58:53 AM • Toshiba... • Answered on May 31, 2008
Will not power on
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the ... This will help verify that the strip or switch is not bad.
Click on the above link and follow instructions.Thank You, Please dont for get to Vote.
5/23/2008 8:48:37 PM • Toshiba... • Answered on May 23, 2008
My laptob could not startup ok what can I do to repair
You need to boot up machine, my toshiba uses F12 to control boot options,F2 to enter BIOS, Your machine is trying to boot from network not cd/dvd or hard drive. you have to change to boot order to cd/dvd or hard drive and make sure they are before network as a boot option,
3/20/2008 8:31:18 PM • Toshiba... • Answered on Mar 20, 2008
System board
I hate to say your getting scammed but...........
First. Price for service is unreasonable.
Second, Slow boot=new mobo? I am very sceptical about that diagnosis.
A few questions if I may.
Are there more than 6 icons in your system tray?(lower right corner)
Are there any programs in the startup folder? Start/allprograms/startup.
Have you de-fragged the comp in a while?
After that, consider this. Can you get a newer laptop for 700 bucks? OK, not as nice as yours. Isn't it still under warranty?
1/26/2008 9:24:47 PM • Toshiba... • Answered on Jan 26, 2008
TOSHIBA SATELLITE P25-S5263
click here for the link
1/21/2008 11:13:04 AM • Toshiba... • Answered on Jan 21, 2008
2answers
Toshiba Satellite P25-S5263 monitor problem
It could be a driver problem perhaps. Does the post screen show at all or is there absolutely nothing?
12/29/2007 6:40:43 PM • Toshiba... • Answered on Dec 29, 2007
Toshiba Satellite P25-S5263 Notebook Logo
34 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite p25 s5263 boot lockup
  • Computers & Internet
