20 Most Recent
Kohler K-9511-BN MasterShower Shower Arm & Diverter - Brushed Nickel Questions & Answers
Shower is dripping. how do you make sure you find
If you're talking about the diverter just like the one in that picture, then no. You do not need to get a Kohler diverter, as Kohler utilizes the 1/2 NPT(national pipe threading) threads that most showers are compatible to. You can pick one up from your local hardware stores. Make sure you teflon tape all the male threads before you install them.
Can this diverter run both
This unit will allow the function of the shower head or the hand held shower individually. You can make both operate at the same time but the performance will be dismall at best.
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
