20 Most Recent Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Questions & Answers
It's definitely coming through the flapper valve. Look for some interference or crud that prevents the flapper from sealing well. Does it happen intermittently, or constantly? If you can't find the interference try a different style of flapper valve. good luck. Al K
Kohler - Toilet... | Answered on Sep 14, 2015
You have to twist the whole thing. There is no nut or threaded portion under the gasket like you'd find on most (two-piece toilets). The hole under the gasket seal is a triangle-shaped and the bottom of the flush valve (the part that says waterline) has three prongs that lock the unit down against the gasket.
I don't remember which direction worked, but I put the grip/handle of a channel lock pliers down into the flush valve and that gave me the leverage to remove the whole part with gasket.
Kohler - Toilet... | Answered on Jun 27, 2015
Snow and Jones wearhouse
Kohler - Toilet... | Answered on Nov 30, 2014
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
Kohler - Toilet... | Answered on Aug 07, 2014
your new seat will have bolts and nuts with it.
Kohler - Toilet... | Answered on Oct 14, 2013
The top of the pipe above the flush valve is threaded. Unscrew it, and you will be able to remove the flush valve and replace the gasket.
Kohler - Toilet... | Answered on Sep 09, 2013
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Kohler - Toilet... | Answered on Dec 27, 2011
flush valve has obstruction and tank is not filling all the way to just below overflow tube.
Kohler - Toilet... | Answered on Nov 06, 2011
may be sticking to something
Kohler - Toilet... | Answered on Sep 04, 2011
Yes and if it is not hooked to the edge of the fill valve or on the end of the fill tube it went down the drain. fluidmaster makes a universal one.
http://www.fluidmaster.com/index.asp?bhcp=1
Kohler - Toilet... | Answered on Feb 13, 2011
a lots of the time when that happens you will need to use a grinder or a ' Dremil ' tool to cut the bolts that are holding down the toilet and get some new bolts and re-install. **** there is also a chance that if you CAN turn the bolt itself from the top that you can get the bottom of the bolt ( which is ' T ' shaped ) to turn in the right direction and get the bolt head to slip through the slots in the floor plate. since you will most likely need new bolts to re-install the toilet, go buy the new bolts at the hardware store and by looking at the bolts and looking at a floor plate at the store -- this will give you a idea of what you are trying to remove.. ( it is kinda like a puzzle ). ******
also --- sometimes you can get a hacksaw blade ( by itself -- not on handle ) to fit between the floor and toilet and cut the bolts that way,, this is kinda a pain to do, but in a pinch it sometimes works good.
I hope these ideas help you --- good luck ( ! ).
c...
Kohler - Toilet... | Answered on Dec 31, 2010
Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Logo
50 questions posted
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
need change
  • Home
