20 Most Recent Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Questions & Answers
hello,
the reason for this that the toilet valve have loss out from it position for the water to be able to flow out completely
what you need to do from here is that you have to open the water carrier that is behide the toilet sitter the valve will need to be adjusted down a bite from the screw that help in holding the valve for the water to be able to flow out as usual
after this then your flush valve will allow all the water to run out to flush the toilet well
Good luck and thanks for using fixya.
Kohler Cimarron... | Answered on Jul 02, 2018
i don't know about your toilet but i googled it and found this it's the flapper and flush valve
https://www.plumbingsupply.com/images/kohler-flush-valve-1044458.jpg
and you can go here and see all the parts in it,hope this helps you out.
https://www.plumbingsupply.com/kohlertoiletparts-cimarron.html
Kohler Cimarron... | Answered on Dec 22, 2017
Made a video on how I fixed this same problem on mine.
Kohler Cimarron... | Answered on Oct 31, 2015
google "house plumbing illustration" and then click on "images" on the top left of the screen it will give you a plethora of images on plumbing. Have fun!
Kohler Cimarron... | Answered on Jun 25, 2015
I would check to see if the water supply valve is turned on to start.
Is it a new install?
Kohler Cimarron... | Answered on Jun 22, 2014
This is usually caused by a partial blockage inside the toilet. Try using a plunger to clear it, if that doesn't work, get a toilet auger from your local home improvement store
Kohler Cimarron... | Answered on Apr 26, 2014
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Kohler Cimarron... | Answered on Apr 14, 2014
you can get a new set of bolts
Kohler Cimarron... | Answered on Nov 29, 2013
try adding washers (stainless or brass) betwee the toilet body and tightning nut use as many washers as you need
andrew
Kohler Cimarron... | Answered on Nov 01, 2013
Hi bubba
You have a blockage between the toilet and the septic tank or drain that is causing the water to flow into the tub
Bud
Kohler Cimarron... | Answered on Apr 24, 2013
You can look at the gasket thats hooked between the flush valve and the toilet and see if its in bad shape and letting water get past it and eventully flushing your toilet. If its bad i would try to find one similar or drain the holding tank and use a little clear water proof silicone on it. Use a paper clip to clean out the hose going to the flush valve and you should be good to go.
Kohler Cimarron... | Answered on Sep 03, 2012
This happens when the floor is not level. You need to keep the tank tight to the bowl. Silicone a shim under the lid on the low side to make the lid level. This will make the tank look level also
Kohler Cimarron... | Answered on Aug 30, 2011
Hi chanryan...
You need to adjust your float level in the tank.
Look on the arm of the float ball and there should be a screw that you can adjust the level of the tank water.
Turn the screw to raise the level of the water in the tank, to just about a 1/2 inch of the overflow pipe
If it will not adjust then you will have to replace the float valve (ballcock...is what it is called)
Please take time to rate me
Kohler Cimarron... | Answered on Jul 04, 2011
Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
59 questions posted
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
kohler elongated toilet about 4 years
  • Home
