20 Most Recent 2000 Oldsmobile Intrigue Questions & Answers
2000 Oldsmobile Intrigue. I was changing the gaskets on the water outlet and I broke off the aluminum skinny pipe located on top of water outlet. How to fix please?
Question edited for clarity and typos. Question moved to model category. You just need to identify the part and replace it. Check the diagram on the top left. If it is part 7 it is discontinued, so you would have to remove it and have it MIG welded. https://www.gmpartsclub.com/v-2002-oldsmobile-intrigue--gls--3-5l-v6-gas/cooling-system--radiator-and-components https://www.google.com/search?q=2000+oldsmobile+intrigue+coolant+parts+diagram ..
1/3/2023 5:40:02 AM • 2000 Oldsmobile... • Answered on Jan 03, 2023
2answers
I changed the crank shaft positioning sensor on my
its on the top of the motor in the front by the cam shafts.
3/17/2022 10:02:39 PM • 2000 Oldsmobile... • Answered on Mar 17, 2022
2answers
MY 2000 OLDSMOBILE INTRIGUE KEEPS OVERHEATING
Possibilities:
Low coolant - check and refill if necessary
Thermostat is stuck shut - replace
Radiator clogged - clean fins of radiator. Have the radiator flushed.
11/15/2021 5:49:17 AM • 2000 Oldsmobile... • Answered on Nov 15, 2021
How to replace hoses on 2000 Olds Intrique
Use channel locks to pinch the fastner then pull the hose off if it doesn't move push the clamp off the hose if still doesn't move then try using the wrench to twist it back and forth then it should come off. Then put new one on and refasten the clamp. U may have tolubeit to get into may want to switch the clamp to new ones
10/18/2021 5:10:29 PM • 2000 Oldsmobile... • Answered on Oct 18, 2021
2answers
My 2000 Oldsmobile intrigue wont start it was hard
If it is not cranking, you must check for battery voltage, if it is cranking you must check for ignition (spark) and verify fuel pressure and fuel delivery to the cylinders.
9/10/2019 6:31:10 AM • 2000 Oldsmobile... • Answered on Sep 10, 2019
3answers
WHEN IT RAINS MY PASSENGER SIDE FLOORBOARD FILLS
you have a leak going through a welded area. The factory uses a seam sealer upon building these cars. So to fix this when the entire car is assembled it quite difficult to do. First you have to locate the nature of your leak. If you can see where it is coming from, great. If not you will need to remove many articles from your car such as the carpet and backing which will have to be removed for proper cleaning from stagnat water sitting in place for sometime now. Any sound board padding going up behind your dash up through the firewall. When all that is removed you can see alot of sheet metal. Inspect all welded seams for traces of rust. That will be an earmark for a leak. Shine a flashlight as far as you can see looking for rust scales throughout.If you have to mix Arm & Hammer baking soda with water 50/50 mix and pour throughout the outside screen into the firewall and watch for that milky film seep into the interior. The soda will ellimanate odors as well for your car. I know this is a tough job which no mechcanic likes to tackle but it does happen to all of us at one point in our lives
Hope you find the leak and get it resealed with a 3M resealing product too
Good luck
1/16/2019 6:46:08 PM • 2000 Oldsmobile... • Answered on Jan 16, 2019
Where does the snap ring go on a fuel pressure regulator for a 2000 oldsmobile intrugue
See illustration It is the last part installed and retains the guts of the regulator in place 0996b43f802307fe-hicotxq4ah03iz2qctcfihyg-2-0.jpg
9/5/2018 10:42:41 PM • 2000 Oldsmobile... • Answered on Sep 05, 2018
2answers
I need to install the fuel pressure regulator
yes a vacuum hose attaches to the fuel pressure regulator
9/5/2018 10:16:19 PM • 2000 Oldsmobile... • Answered on Sep 05, 2018
I have a 2000 Oldsmobel Intrigue and i changed the battery. Let it set for 15 minets had power until I turned the key
Double check your connections to the battery and also the starter. Be careful at the starter with battery connected you don't want to touch any metal with your wrench while tightening the wires best to disconnect wires to battery then tighten starter positive then reconnect batter terminals.
4/15/2018 4:51:55 PM • 2000 Oldsmobile... • Answered on Apr 15, 2018
I have a 2000 Oldsmoble Intrgue put a new battery in and I thik the anti theft has shut down the car.
GO to this Link and scroll down to a December 25th, 2007 post where it describes (in great detail the process): Resetting the securty system Oldsmobile Forums Anthony
4/15/2018 1:32:58 AM • 2000 Oldsmobile... • Answered on Apr 15, 2018
My daughters 2000 olds intrigue has a blown 40a
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram, fuse diagram, troubleshooting, PCV, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
3/21/2018 5:22:43 PM • 2000 Oldsmobile... • Answered on Mar 21, 2018
Dashboard Lights
All are controlled by the ECM computer. I would suspect a bad ground. But wiring could be the culprit also along with the big connector in back of the dashboard. Poke around.
2/15/2018 9:59:56 PM • 2000 Oldsmobile... • Answered on Feb 15, 2018
Intrigue stereo shows clock and gets power but doesn't light up and play CD or radio
There can be up to three separate power lines to the radio - ignition, dash light and auxiliary (always on). Check the ignition power wire for good connection and possible blown fuse.
1/4/2018 10:13:44 PM • 2000 Oldsmobile... • Answered on Jan 04, 2018
How to remove passenger side door panel, for 2000 Olds Intrigue?
1. Remove the door latch trim plate (coupe and sedan front doors). 2. Remove the ashtray (sedan rear doors). 3. Remove the seat belt retractor cover (coupe and sedan front doors). Use a suitable door trim panel removal tool to release the clip retainers 4. Remove the door lock trim plate and the power window switch, if so equipped. 5. Remove the window regulator handle by removing the inner retaining clip, if so equipped. 6. Remove the remote mirror control, if so equipped 7. Remove the trim panel retaining screws 8. Remove the door trim panel using a door trim panel removing to work loose the retainer clips. 9. Detach all electrical and remote mirror controls, as required. To install: 10. Install the wiring harnesses through the openings in the panel, as equipped. 11. Position the trim panel to the door and align the clips. Press the trim panel to the door until all the clips are fully engaged. Align all the holes before engaging the clips. 12. Install the screws, remote mirror control and inside door handle bezel, as equipped. 13. Install the window regulator handle or power window switch. 14. Install the door trim plate, seat belt retractor cover or ashtray.
12/4/2017 9:56:13 PM • 2000 Oldsmobile... • Answered on Dec 04, 2017
How to reattach rear-view mirror
Super glue
12/2/2017 5:36:32 PM • 2000 Oldsmobile... • Answered on Dec 02, 2017
2answers
My car is getting hot in idle, what is wrong?
Check first your coolant level. Start engine and turn on ac open hood see if cooling fans are running, if fans are running and coolant level is ok temperature should stay normal. If temperature rises squeeze coolant hose, it should be firm like you could feel pressure on the hose a sign that the water pump is good. Thermostat opens only when coolant reach normal operating temperature.
11/7/2017 4:09:59 AM • 2000 Oldsmobile... • Answered on Nov 07, 2017
2001 intrigue not starting
If starter is clicking but not turning, usually an electrical problem or faulty solenoid. If nothing happens but lights dim, starter may be jamming. If no other electrical problems with the car (such as an intermittent battery failure), check the electrical connection at the solenoid for looseness or corrosion. If there is full 12V power at the starter solenoid and it still won't start, replace the starting motor.
10/15/2017 9:43:08 PM • 2000 Oldsmobile... • Answered on Oct 15, 2017
1,429 questions posted
Popular Products
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
View Most Popular
Intrigue Oldsmobile
  • Intrigue Oldsmobile
Most Popular Question
heat stopped working in 2000 oldsmobile
  • Cars & Trucks
