20 Most Recent
Canon IXY 1000 Digital Camera Questions & Answers
Photograpgs wiped by accident
Try putting the memory card direct to your computer and try download images. If you get the same message then I'm afraid it looks as if you have wiped the images
Not ale to dowload photos to my laptop
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
Japanese to english
Turn the mode dial to Playback (the right-pointing triangle). Hold down the FUNC/SET button, and press the MENU button. Use the arrow keys to select a language and press the FUNC/SET button.
Japnese english
I took photos in a larger canon camera with a 4g
I have had success with this... Download this
camera photo recovery program called asoftech photo recovery
http://www.asoftech.com/apr/You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.If needed, you may format (use quick format) the memory card and then use asoftech photo recovery to recover your files.
Use digital camera as a webcam
Yes it is possible! For Canon, there are many software programs which allow you to do so! Things like extrawebcam or Canonwebcam will do the trick!
