20 Most Recent
Yukon 24041B Monocular Questions & Answers
I have bought one of
it actually has minute black clip locks.disassembling it manually will dame or may be break that clip locks.its not easy to remove this locks without proper tools.the screws are simple to remove but locks are bit delicate .
did you tried this for adjusting the shap viewing
Brightness Adjustment Wheel
The Ranger's image is shown on a Liquid Crystal Display (LCD). Manual adjustment of the LCD brightness is operated with the adjustment wheel.
Power Supply
The Ranger can operate on external power sources such as a vehicle's or stationary power grid (the device is equipped with a special output for that) or independently on AA batteries/accumulators.check out and reply.keep updated.
Yukon 2.5 x50 nvrs tactical
Hello, don't worry about it. It is HV to the image intensifier tube. The battery
voltage goes through control circuit then to ccfl inverter (here is were dc
voltage is switch on and off and switch dc voltage is step up by toroid coil
that has two input and only two out puts). By impulsing the coil with two
different switch dc voltage on the input this make the current lag the two
different phase voltage by 90 degrees. Here is where the strange noise is coming
from. The toroid coil is encased in iron case and if half of this iron case is
loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call
it AC because that what AC voltage is, it switch between positive to negative)
this voltage is about 300 to 900 switching DC voltage. This voltage will be
applied to a 1/2 wave voltage multiplier (this voltage multiplier with have
anywhere four four stages to 10 stages depend on what the input voltage to
multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will
have.
Now, the voltage multiplier will double the voltage per stage to need image
intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever
one wants to call it. This voltage will bit you but it doesn't have a lot
current associated with it, the current would be in the 10 to 15 ua (micro-amps)
1/10X6 amps.
Now, you know. GB...stewbison
9/24/2011 8:53:00 PM •
Yukon Optics
Answered
on Sep 24, 2011
Cross hairs do not adjust. Tell me what to do please?
All question need FULL 'make model (what it is)'.
You posted to optics, so let's guess is a telescopic rifle sight?
It is impossible to see and movement as the crosshairs move such a tiny amount. Half a millimetre in the sight is 10 feet at the target. The only way to zero in sights is on a fixed bench rest at the range.
If you really think they are faulty, return them to the maker for repair.
3/8/2023 1:07:51 AM •
Optics
Answered
on Mar 08, 2023
I have a NexStar 90GT with no hand control, a replacement will cost $135, is it worth it to buy for this telescope?
Whether or not it's worth it to buy a replacement hand control for your NexStar 90GT telescope depends on a few factors:
- How often do you use the telescope? If you use it frequently and rely on the hand control to find objects in the sky, then it may be worth it to invest in a replacement.
- How important is the hand control to your observing experience? If you're comfortable manually finding objects in the sky and don't necessarily need the hand control, then it may not be worth the expense.
- Can you find a cheaper alternative to the official replacement? Sometimes, third-party sellers may offer hand controls that are compatible with your telescope at a lower price.
Ultimately, it's up to you to decide whether the cost of the replacement hand control is worth it based on your individual needs and preferences.
2/25/2023 7:57:32 PM •
Optics
Answered
on Feb 25, 2023
No zoom function on a kalimar power zoom scope,
larry389's so-called solution is not a solution... just an opinion to which each individual is entitled... even when not correct! I've used a Zeika Opt. Co. Power Zoom Binocular No.25361 for over 25 years since inheriting them from my father who purchased them in early 1970. To say the least, treated carefully and with respect for the delicate instrument that they are, they've been wonderful and still work perfectly fine. Perhaps Larry's experience is based upon handling them like junk and, therefore, reaping what he has sewn.
2/6/2023 8:12:30 AM •
Optics
Answered
on Feb 06, 2023
