20 Most Recent Yukon 100X (6-100x100) (6-100x100 mm) Questions & Answers
As long as you use a special lens cleaning cloth it will not hurt the lens, it is the same cloth that is used to clean eye glasses or any camera lens. You can buy these almost anywhere.
Yukon 100X... | Answered on Nov 05, 2018
When you say lens, did you unscrew the eye piece or the actual lense? because the eyepiece is meant to fit your adaptor for 35mm cameras etc. but the actual front lense should be tightly sealed and thread locked to make your glass (scope) waterproof to some extent and to protect the alignment of the other lenses within your scope. If it is possible your local camera shop may have the ability to re-align and seal your scope, but if not do you have a warranty? and if not even that, if i were you i would align and accraglass your piece back together, it's a last ditch solution that should last for years.
Yukon 100X... | Answered on May 06, 2008
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Yukon Optics | Answered on Sep 24, 2011
Back or front ?
Optics | Answered Yesterday
put a dead mouse on it
he i need a tripod to reflector telescop 525
Optics | Answered on Apr 14, 2019
We do not do appraisals.
We can't see what you have can we and it would be impossible to guess. All the models are pictured in the link
https://www.google.com/search?client=firefox-b-d&tbm=isch&q=springfield+precise+time
Optics | Answered on Apr 13, 2019
Yukon 100X (6-100x100) (6-100x100 mm) Logo
4 questions posted
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
clean lens scope some cloth without
  • Optics
