20 Most Recent Yukon 28041 Binocular Questions & Answers
2answers
Yukon Ranger 5 x 42
Hello, let do this. IR illuminator has a montary switch, that is when you push it comes on, and when you release it the IR goes off and it has a red LED to indicate the IR illuminator is being activated.
When you turn you binocular on there will be a green LED activated. This switch is DTSA---double throw sing activated. That is, one throw of the switch it turns on the binocular, the throw will turn off the binocular.
Also within the control panel there is timing circuit to keep the IR illumniator on for ten second the shuts off. Make sure you have the right switches etc. Let me know, then we can brain storm on this matter. stewbison
3/7/2012 7:05:54 AM • Yukon 28041... • Answered on Mar 07, 2012
I need a manual for a yukon ranger digtal 5x42 binoculars
Here:http://main.yukonopticsglobal.com/ranger-5x42-digital-night-vision.html
1/15/2012 11:26:06 PM • Yukon 28041... • Answered on Jan 15, 2012
Green light comes on but no picture. where is best
Hello, most of these night vision devises are repaired by the companies that offer to sell and service. It almost impossible to find someone other than the dealer to repair them. You try Morrision Optic they have big web page on the Internet. A little warning here. These companies they sell NV devises are not necessarily the manufacture of these NV devise. Russian make a lot of these NV devises for US NV companies.
I repair them also but it hard for me to get parts, and I can make other parts if I can find some dealer that will sell me parts For a 1st generation cheap Russian image intensifier tube will cost about $175 each and sometime I can get them cheaper. GB....stewbison
9/11/2011 3:48:32 PM • Yukon 28041... • Answered on Sep 11, 2011
The Main IR Light. (the one used for long
Here we go. Take it to electronic repair facilities. See if the can replace the LED IR. Now if they want. Call Yukon NV Optics and see what the charge, normally these companies have flate fee they will charge. They really don't make it easy for the owner to repair these NV binocular. Basically, the binocular will almost be totally taken a part. stewbison
8/11/2011 6:53:11 PM • Yukon 28041... • Answered on Aug 11, 2011
0answers
Unable to see
Be the first to answer 10/25/2013 4:31:59 AM • Yukon Optics • Posted on Oct 25, 2013Be the first to answer
Yukon 2.5 x50 nvrs tactical
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
9/24/2011 8:53:00 PM • Yukon Optics • Answered on Sep 24, 2011
3answers
How do I change Language on a sokkia set 250x total station
hi deshwashin error vod d13 brandt thnks
4/4/2024 7:00:30 AM • Optics • Answered on Apr 04, 2024
Need manual for edu science star tracker telescope
Yes I do
1/13/2024 1:28:24 PM • Optics • Answered on Jan 13, 2024
Tascos riflescope 3x9x50 adjutment caps
Visit your local gun shop and have them order them.
10/17/2023 10:13:50 PM • Optics • Answered on Oct 17, 2023
I need firing order for a 1981 Johnson seahorse 115
its just 1-2-3-4- with the port bank being 2-4 starting at the top and the starboard side being 1-3. They're all the same be it V-4 or V-6. 6=123456 60* and 90* are the same
5/31/2023 9:13:49 PM • Optics • Answered on May 31, 2023
Prime bluetooth wireless keyboard is not working
If the batteries are worn out or have not be put in properly. You may have to resync your devices the the USB receiver.
5/1/2023 6:31:18 AM • Optics • Answered on May 01, 2023
Franklin Chef FCE-42R Espresso Machine. How do I get a owner's manual for it please?
Question edited for clarity. Duplicate Question deleted. It doesn't seem to be available https://www.google.com/search?q=Franklin+Chef+FCE-42R+manual ..
3/13/2023 6:44:38 PM • Optics • Answered on Mar 13, 2023
Cross hairs do not adjust. Tell me what to do please?
All question need FULL 'make model (what it is)'. You posted to optics, so let's guess is a telescopic rifle sight? It is impossible to see and movement as the crosshairs move such a tiny amount. Half a millimetre in the sight is 10 feet at the target. The only way to zero in sights is on a fixed bench rest at the range. If you really think they are faulty, return them to the maker for repair.
3/8/2023 1:07:51 AM • Optics • Answered on Mar 08, 2023
Yukon 28041 Binocular Logo
7 questions posted
Top Yukon Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
green light comes but no picture best
  • Optics
