20 Most Recent
GE 24 in. Monogram ZBD6880KSS Stainless Steel Built-in Dishwasher Questions & Answers
Will not finish cycle without restarting
Hello. When looking up your unit for the service manual, I found that it might be subject to a service flash--potential fire hazard. You will need your complete model and serial number. Call GE (877) 275-6640, and find out if your washer is in the list. There is a condensation problem in the door which can cause moisture to drip down onto the control board causing a short circuit. There needs to be a cover over a fuse on the board. If your unit has a green dot next to the sticker which has the model/serial number on it, it's already been modified. If not, then GE will send a parts kit and you will have to get a tech to install it.
10/15/2015 9:14:33 AM •
GE 24 in....
Answered
on Oct 15, 2015
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way.
A.
1/5/2012 1:49:01 AM •
GE 24 in....
Answered
on Jan 05, 2012
Water remains under the 4
First make sure your homes drain pipe is not plugged up. If not remove the drain hose where it connects to the drain pump. you will see a flapper valve(thin rubber piece) #328 in the diagram,this is probally allowing water to flow back into the machine. A common problem with this model the flapper gets torn or worn out. They are inexpensive and easy to replace. Enter your model # at
www.appliancehelponline.com and diagrams will come up for your model.
11/5/2010 5:24:25 PM •
GE 24 in....
Answered
on Nov 05, 2010
Our dishwasher has started leaving
I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not WorkingDishwasher Maintenanceheatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
10/11/2010 11:45:48 PM •
GE 24 in....
Answered
on Oct 11, 2010
Touchpad on GE monogram not working right
This is a pretty expensive repair that I don't usually recommend. You have a bad touchpad assembly, and may have a bad main control board. This is a pretty expensive maybe, with no perfect way of diagnosing both problems, without first installing the touchpad and testing to see if it is the only bad part. You can check to see if there is any warrantee left on the electronic parts. If your Dishwasher is only 2 to 5 years old, your owners manual will usually tell you what warrantees you have. Some only have a year warrantee, some have a 2 to 5 year electronic control warrantee. Also we are seeing a lot of these repairs right after there was a power surge in the area. You can have your dishwasher rewired by installing a normal receptacle that is accesible to you, and install a surge protector that your dishwasher is plugged into. You can also have an electrician install a surge protector for your whole house, in your circuit breaker box. If you do replace your dishwasher, the dishwasher that I have the fewest repairs with is the Whirlpool/KitchenAid model.
2/8/2010 6:19:56 AM •
GE 24 in....
Answered
on Feb 08, 2010
Has anyone reported smoke coming out of the unit
What kind of unit is it? What Brand, model, etc.. How long have you had it. Is it hard wired. This is an indication that you have a short somewhere. Is the item still under buyers warranty, or from the manufacture. If you can provide me with additional info I might be able to assist you further. Hope this helps.
JimmyC
9/25/2009 3:25:14 AM •
GE 24 in....
Answered
on Sep 25, 2009
GE Monogram 24" Dishwasher not quite getting the job done
Th ete first thing to do is put a pack of limonade unsweetened through a wash, it will clean any hardness minerals. Next be sure the heat element is working properly, then consider replacing the pump/motor assembly, fairly easy you can prts online.
8/12/2009 1:07:43 PM •
GE 24 in....
Answered
on Aug 12, 2009
Buzzer won't stop; electronic controls are frozen
Something has shorted in the unit where the buzzer is. It ran on a small circut board and this will need to be replaced at this time, also since the controls are frozen this give me the same conclusion that the board in the unit has malfunctioned, you will need to contact the manufacture for a local autherized repair person to replace this bard inside that controls the functions and buzzer in the unti. If you found this information helpful please rate it accordenly - Thank You for using Fixya.com it was my pleasure serving you today!
Rulds2008
GURU Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/28/2009 9:41:28 PM •
GE 24 in....
Answered
on Apr 28, 2009
Purchased a used Monogram Dishwasher/no factory info was included
First, here are some tips to help with your model number: look for an aluminum tag--or a silver or white adhesive label. The model number may be printed or
stamped onto the tag and it may be written in two different type sizes or styles. You might find the tag in one of these places:
- Inside the door jamb, to the left, right, or top
- On the door, to the left, right or top
2/12/2009 2:19:23 PM •
GE 24 in....
Answered
on Feb 12, 2009
