20 Most Recent GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Questions & Answers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
7/6/2022 2:23:16 AM • GE 25 in.... • Answered on Jul 06, 2022
0answers
Dishwasher won't fill with enough water
change you water inlet valve your water level is to low remove kick plate look to the left front thats where you.ll find the water valve remove the power plug from the water valve then take some pliars and remove the black hose by removing the clamp reverse prossess
1/15/2014 3:18:36 PM • GE 25 in.... • Answered on Jan 15, 2014
Connector to the faucet for GE Nautilus portable dishwasher
We just bought a used version of the GE Nautilus and we were able to get a generic "fits most portable dishwashers" adapter and it worked great. We went to Fred Meyer (which I believe is a Kroger company in the NW) and it was the only one they had. It only cost $3.99. The brand is Plumb Craft by Waxman and the model number is 76-127. Dishwasher Faucet Aerator. Hope this helps!
Good Luck!
12/18/2013 11:19:44 AM • GE 25 in.... • Answered on Dec 18, 2013
2answers
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
2/28/2013 5:53:41 PM • GE 25 in.... • Answered on Feb 28, 2013
2answers
GE Nautilus Dishwasher
if the dishwasher has not been used for a few weeks, the water in the sump that goes into the pump will evaporate causing the pump to freeze up. usually you can turn the fins inside the motor to free it up. make sure the dishwasher is not on when you do this.
2/16/2013 8:20:02 PM • GE 25 in.... • Answered on Feb 16, 2013
Water leaks when black valve hooked up to water tap
Hello Wes. Begin by installing a new o ring. Take off the old one and take it to a hardware store to get the correct replacement. Also pick up a little tube of O ring lube.
1/25/2013 7:30:49 PM • GE 25 in.... • Answered on Jan 25, 2013
2answers
GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
10/4/2012 12:43:37 PM • GE 25 in.... • Answered on Oct 04, 2012
2answers
I want to install my portable ge nautilus
GE has a kit available for the undercounter installation of this dishwasher, I recommend the purchase of this kit to simplify your install.
GE kit # WD35M34
Good Luck !
9/21/2011 1:53:36 PM • GE 25 in.... • Answered on Sep 21, 2011
My portable dishwasher does not
Hi and welcome to FixYa, I am Kelly
This is usually caused by the plastic float in the bottom of the unit being stuck OR a failed float micro-switch.
The parts you need to look at are items 302, 305, 306, 307, 308 and 490 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224401&diagram_id=26124425#d26124425
Check the stem from the BOTTOM. It should slide up and down freely. Listen for the microswitch to CLICK as you lift it up and down. No click = bad switch. If it is sticky you will have to remove the float and clean the whole assembly.
Concentrate your efforts in this area and I am sure you will resolve the issue.
Thanks for choosing FixYa,
Kelly
9/11/2011 10:47:57 PM • GE 25 in.... • Answered on Sep 11, 2011
0answers
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
124 questions posted
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
GE Dishwashers
  • GE Dishwashers
Most Popular Question
ge nautilus dishwasher not drain all
  • Dishwashers
