20 Most Recent LG Flatron Ez T910B 19" CRT Monitor Questions & Answers
2answers
He instalado windows 7 necesitaria
Windows 7 busca autom?ticamente los controladores para el video. Usted no necesitaun controlador para el monitor.
6/6/2016 6:31:20 AM • LG Flatron Ez... • Answered on Jun 06, 2016
0answers
Lg ez t7108
Be the first to answer 12/20/2013 7:33:07 PM • LG Flatron Ez... • Posted on Dec 20, 2013Be the first to answer
2answers
LG Flatron EZ T530S
Check your connector to your computer if that's good check the HOT if it's bad replace the HOT and flyback. Check the SMPS caps.
3/18/2013 6:49:07 AM • LG Flatron Ez... • Answered on Mar 18, 2013
LG Flatron W2252TQ does not power up. When I turn the PC on, the blue light momentarily turns on before turning orange and then reverting back to grey.
ok try this one switch the hard-drive off and on again to restart it and then the screen would come one.
7/19/2022 10:19:51 PM • LG Flatron... • Answered on Jul 19, 2022
I was cleaning the screen of my lg flatron w2053tp and the screen went black. The power is on and I can bring up the menus but otherwise nothing
Check the all the cables. Check input settings by using the menu.
8/3/2021 7:29:51 AM • LG Flatron... • Answered on Aug 03, 2021
Hey I have an LG Flatron L1718S screen that work fine for a few weeks then suddenly switch off for a few days ,then switch on again,it's a irritating cycle.Please HELP
  • Larry Ng Jul 15, 2021that is just a YEAR 2007 LCD computer monitor, it needs a computer to work. if it fails in a 2nd PC , if that test fails,the monitor is bad. (hardward failure, monitor. the tests are simple, it fails on 2nd good PC, what can be more simple that test ANY 14 year old monitor on a 2nd good PC. when dead do this.(test2) they are all here when dead again use a FLASH LIGHT. (or in UK a low carbon foot print TORCH)<< joking. https://pcdied.com/monitors_and_screens/... all monitors older than 2010 do this . (has CCFL inside and that is never fun now) the cure is newer monitors 2011 to now called LED monitor.s or OLED. the tubes are cold cathode florescent tubes. (back lamps.) (have 5 classic fail symptoms not just dead) they are short lived, laptops and monitors both back then. 20,00hours on the clock and go bad. bank on it. the 3 failures are CCFL, PSU board, and logic board #1 is CCFL the all died long ago, on average about year 2003 (07 +5= 12, 2012) at 20,000 yours boom dead. or intermittent. PSU is here: https://pcdied.com/monitors_and_screens/... below is logic board. one of the 3 fail, CCFL tubes dead is like 99% we retire them if the CCFL test fails. (using bench PSU to test them) but you have non of that so. upgrade
  • Larry Ng Jul 19, 2021 logic board. (CCFL tubes dead, PSU dead, or logic board dead) and or thermally failing , and bad.
  • Anonymous Jul 23, 2021 99% of all monitors are all dead. due to those silly low live CCFL back lamps. or the 2cards inside that can fail too. PSU card +HV CCLF power or the Data card is dead. 99.9% of folks seen these facts, upgrade now. high voltage inside 600v on the CCFL pins
7/23/2021 3:55:07 PM • LG Flatron... • Answered on Jul 23, 2021
Monitor slow to display picture
Hi, Sounds like an issue of the video card not the monitor. Take to computer shop to verify. One thing you can try is drop the dpi down (refresh rate)a bit. Then try again. If that makes sense to you. Hope that helps.
2/10/2018 9:41:36 AM • LG Flatron... • Answered on Feb 10, 2018
Installing mount on LG Flatron
Hello, It´s not safe to anchor it to the plastic back, monitors usually have a metal frame inside that support the weight of the monitor.
11/12/2017 9:54:47 PM • LG Flatron... • Answered on Nov 12, 2017
Flatron l17175 has it internal wireles receiver
Flatron l17175 what on earth is that? ahhhhhh and LG, lucky Goldstart monitors. not HP. wrong forum Ill move you.
10/16/2017 11:14:22 AM • LG Flatron... • Answered on Oct 16, 2017
0answers
Why does my LG flatron 1953T-BF LCD monitor (19') has no power?
You need to use a ESR meter to check capacitors
3/2/2017 2:27:25 AM • LG Flatron... • Answered on Mar 02, 2017
2answers
Lg flatron e2441 half screen darker
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
8/22/2016 4:20:38 PM • LG Flatron... • Answered on Aug 22, 2016
When ipluh in and switch on my monitor all the screen displays msg analog power saving mode how do i get rid of this and just get to work normally again please help
Normally your computer display goes to sleep mode when the attached cpu is not turned on..
7/29/2016 10:56:18 AM • LG Flatron... • Answered on Jul 29, 2016
Turn on internal wireless receiver
Settings.... Wireless
6/23/2016 3:57:20 PM • LG Flatron... • Answered on Jun 23, 2016
0answers
Range meaning
Be the first to answer 11/9/2015 5:11:21 AM • LG Flatron... • Posted on Nov 09, 2015Be the first to answer
LG Flatron Ez T910B 19" CRT Monitor Logo
8 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
  • Computers & Internet
