20 Most Recent LG 22" FLATRON LCD Monitor Questions & Answers
4answers
Subtle Two Toned Split Screen Color Difference.I think I hit some button by accident. Monitor is great but now I have a split screen where the left hand side of the screen has a lighter tint than the
Hi. I have got the same problem, and it was very easy to solve. Monitor was LG. The problem was not in the system, it was in the monitor. I just clicked the buttons on the monitor, it was on the wrong setting that divides monitor in two colors, so if it happens to you, try checking your monitor settings, mine was set to "demonstration", half was lighter than the other one, just set it to usual or user. Keep in mind the settings are on the monitor itself, not in the windows (buttons on the monitor itself) Good luck.
2/11/2019 1:06:03 PM • LG 22" FLATRON... • Answered on Feb 11, 2019
0answers
LG E2240T-PN driver periodicaly reset,
You can try starting laptop first and TV after some time or vice versa, tv first.
3/3/2018 1:04:41 AM • LG 22" FLATRON... • Answered on Mar 03, 2018
I hav a LG flatron
The spark you saw possibly blew your monitor
6/8/2017 8:17:21 PM • LG 22" FLATRON... • Answered on Jun 08, 2017
Mr Pateman
This is more likely an issue with you video card than your monitor, do all the monitors you have tested operate at the same resolution and refresh rate? It sounds like the LG monitor is running at a higher resolution and refresh rate which is causing addition load to be placed on your video card causing it to crash
5/15/2017 6:26:09 AM • LG 22" FLATRON... • Answered on May 15, 2017
3answers
MY LG 20LS7D TV WILL
You have lost your original remote and got into this by pressing info select and the option 7 UART Download. Happened to my 95 year old aunt in assisted living. You will need the original remote and simply hit (EXIT) or another LG branded remote that has the (ROUND RETURN BUTTON) on the left. Once you accidently get in to this, I have not found a universal Zenith remote that can get you out even though Channel up/down and basic funtions work.Bud retired Bud's TV Service.
3/15/2016 1:34:28 PM • LG 22" FLATRON... • Answered on Mar 15, 2016
How to open lg lcd flatron L1552S
help what open monitor flatron l1552s ? for fix
9/22/2015 6:04:25 PM • LG 22" FLATRON... • Answered on Sep 22, 2015
2answers
I get (D-sub out of range 53.6 k hz / 85 h z) how
this is a how to video on how to fix the video out of range error.
3/29/2015 5:29:41 AM • LG 22" FLATRON... • Answered on Mar 29, 2015
2answers
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
9/21/2014 6:46:07 AM • LG 22" FLATRON... • Answered on Sep 21, 2014
My lg monitor screen is black. It powers on but no picture or light. What could be wrong?
Several things, it could just be turned down real low but most likely it is not getting a signal from the source. What color is the light on the bottom. If it is not green you have an input signal problem.
8/13/2014 2:35:03 AM • LG 22" FLATRON... • Answered on Aug 13, 2014
0answers
Cannot change settings om the monitor displays
try separating the wiring. Touching wires can cross-talk the signals and keep it from being normal.
6/22/2014 5:05:38 PM • LG 22" FLATRON... • Answered on Jun 22, 2014
2answers
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
4/29/2014 5:55:47 PM • LG 22" FLATRON... • Answered on Apr 29, 2014
OSD Locked How do I unlock
Hold the MENU button for 5 seconds, the 'OSD LOCKED' will appear, to unlock, hold MENU button for 5 seconds, the 'OSD UNLOCKED' will appear. It may not work on ALL LG LCD panels.
Please post back, otherwise check the owner manual.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
4/26/2014 6:35:48 PM • LG 22" FLATRON... • Answered on Apr 26, 2014
0answers
LG 22" FLATRON LCD Monitor Logo
347 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
get d sub out range 53 6 k hz 85 h z
  • Computers & Internet
