20 Most Recent
Sony CLIE PEG-NX73V Handheld Questions & Answers
How can i open pdf
Should tell you in the manual
http://www.manualnguide.com/dl/4009/
If not it may not be able to open PDFs
5/7/2011 3:32:18 PM •
Sony CLIE...
Answered
on May 07, 2011
I have several pics that I want to print. My disc
what windows operating system is your computer running on? Is it window xp, vista, or win 7?
If the disc says that your computer is not compatible, then there is nothing you can do other than to install the disc on a compatible computer. Once a disc say its not compatible with a computer, you can force such disc to install on the computer and even if you do, it won't perform well and it will be of no use. So the best thing to do is to install the disc on a computer that it will be compatible with so that it can perform its functions to the fullest.
I'm sure you did not try the disc on a windows xp system, because windows xp should be compatible with the disc. So which every operating system your computer is running, try to install the disc on another computer using a separate operating system distinct from the one on your computer.
I hope you understand my explanations.
Take care.
5/28/2010 3:58:00 PM •
Sony CLIE...
Answered
on May 28, 2010
Broken power on buuton
Try to use the Voice Rec Buton on the right side : on my PEG NX73V, it switchs on. Then you've just to quit the recording mode.
But this solution needs to have the electricity to come up to the board.
10/20/2009 10:29:35 AM •
Sony CLIE...
Answered
on Oct 20, 2009
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
