20 Most Recent
Sony CLIE PEG-N760C Handheld Questions & Answers
My husband is cheating on me
This is not really anything that is covered on fixya.com. Though in my honest opinion. You should really know someone before you marry them. So its up to you to decide if you want to work it out and get marriage counseling or get a divorce. I would rather live alone then live a lie. Good luck and I hope things work out for you.
Thanks,
Lee
7/18/2018 12:29:03 PM •
Sony CLIE...
Answered
on Jul 18, 2018
Sony Clie Palm OS 4.1
is easy, I learned yesterday it was reviewing. Just go to: http://esupport.sony.com/US/perl/swu-download.pl?mdl=PEGT415&upd_id=1037&os_id=10 that you download and then install it and go to this link: http://esupport. sony.com / US / perl / tutorial-display.pl? tut_id = 75 & = PEGT415 CDM. And there's going to solve all
6/24/2009 8:00:05 PM •
Sony CLIE...
Answered
on Jun 24, 2009
Sony Clie n760 memory stick not detected when inserted
Do you share this memory stick with other devices? If you pulled out the memorystick before the device(s) were finished closing the connection, the card may be corrupted. Another thing may be because your memory stick may be too large for your handheld to support. if you don't wanty to refund your $ just shrink the memory stick into a gig or less. You have to have a pc with a memory card reader that supports memory stick. just open up my computer> right click the memory stick> Fortmat and select a smaller size to format to.
6/24/2009 7:54:46 PM •
Sony CLIE...
Answered
on Jun 24, 2009
Hot sync with vista
I have Vista Home Premium and I hotsync my peg-n760c using Palm Desktop. It came with version 4.1, but it was a disaster. The Cd is old and isn't compatible with Vista. So I downloaded an upgrade from Palm.com and I definitely don't use the Jukebox software that came with it either. Go to Palm.com and download PalmDesktop Win62.exe and install it. It should recognize your USB connection and hotsync immediately. Also, use Windows Media Player and change the files to mp3 by using a free program called Switch. Just google Switch and download the basic program. Then load the mp3 files onto your memory stick in Windows Explorer. Then use MSimport to load the memory stick files into your handheld. Good luck!
terymo2
3/4/2009 12:23:57 AM •
Sony CLIE...
Answered
on Mar 04, 2009
Sony Clie PEG-N760C hot sync with Windows Vista
I had the same problems. I downloaded PalmDesktop Win62.exe update from Palm.com and it recognized my USB connection, did away with the port error and hotsynced immediately. I messed with that thing for 3 weeks before I finally tried the update. It says it's not for the peg-n760c, but it works! I don't think they want you to update, but rather buy a new pda. Good luck!
terymo2
3/4/2009 12:17:57 AM •
Sony CLIE...
Answered
on Mar 04, 2009
Screen Calibration
Check for protective film/screen debris build-up around edges.
Check for loose cabling plugs into the back of the Screen
Unscrew the four little fascia screws & lift panel out.
I had same problem after unable to enter password.
Did Hard reset, encountered the stylus calibration cycling error.
One of my screen cables had come adrift slightly at one corner.
1/30/2009 7:45:26 AM •
Sony CLIE...
Answered
on Jan 30, 2009
PEG NX70V
are you syncing alot of medai or do you have large files on your handheld? if you do manually delete them from either a memory card or the handheld. this happens to me when i try to hotsync my palm, just unplug the hotsync cable when it seams to stop then reset your device. you could just take out your memory card too.
7/4/2007 9:03:55 PM •
Sony CLIE...
Answered
on Jul 04, 2007
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
