20 Most Recent
Sony CLIE PEG-UX50 Handheld Questions & Answers
Lost the password
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
12/4/2012 11:49:55 AM •
Sony CLIE...
Answered
on Dec 04, 2012
Just fully charged Sony Clie'---backlight is too
You can set your pen drag function to adjust the brightness.
Click the drop down menu on the top right of your screen, then click "system", then "prefs", then click the button at the bottom of the screen that says "pen". Next, click the drop down menu beside the little icon that looks like your clie. Click that and select "brightness". Now, when you drag your stylus from the bottom to the top of the screen, a little slider bar will appear to adjust the brightness.
10/20/2009 10:50:58 AM •
Sony CLIE...
Answered
on Oct 20, 2009
I have a Sony Clie
I simply found my installation disc! Without this, I think the problem is insoluble.
2/4/2009 8:25:55 PM •
Sony CLIE...
Answered
on Feb 04, 2009
Back light out
i went to preference>settings>power savings and i turned off power saving mode
7/29/2008 3:11:53 AM •
Sony CLIE...
Answered
on Jul 29, 2008
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
