20 Most Recent Sony CLIE PEG-SJ22 Handheld Questions & Answers
Sony Clie sj22
IN BIOS SCREEN SET ALL TO DEFAULTS, BEFORE TRING TO INSTALL RE-PARTION DRIVERS
2/8/2012 9:51:32 PM • Sony CLIE... • Answered on Feb 08, 2012
How do I do a hard reset?
Remember that when you hard-reset, all of your personalization and information will be deleted. Here are the steps:
  1. Press the POWER button
  2. KEEP holding the Power button down, use the stylus pin to gently press and release the Reset button (on the back in the middle of the device) - don't take your finger off the Power button
  3. When the "palm powered" screen is displayed, release the Power button after 3 seconds.
  4. You'll receive a warning message that you are about to delete everything
  5. Press the Scroll button (bottom and center of the device with the triangle symbol on it.
You have now officially hard reset the system and you will need to go through the initialization process again.
2/9/2011 10:21:28 PM • Sony CLIE... • Answered on Feb 09, 2011
Little adapter that plugs into both sony clie sj22
Same thing happened to me. If you search Amazon for SJ22 sync cable, you should find some. I ordered $9.95 five-foot cable from Amazon (via Boxwave)--it says In Stock, but then they said it is no longer available, and I had to buy $15 version with retractable very thin cable--hope it lasts.
Downside is that computer needs to be on to charge device.
If you want to pay $30, the original package appears to be available at:
http://www.amazon.com/Sony-PEGA-AC10-AC-Adapter/dp/B00005Y3Y2/ref=pd_cp_e_0
2/6/2011 11:34:39 PM • Sony CLIE... • Answered on Feb 06, 2011
How can i obtain the
The software available for this device can be installed in compatibility mode in Windows 7. For this do the following.
1. Right click the installer file and choose properties
2. Go to the compatibility tab and check mark "run this program in compatibility mode for"
3. Choose Windows XP Service pack 2
4. Click Apply.
The latest drivers and files for this device are also available from:
http://esupport.sony.com/perl/swu-list.pl?mdl=PEGSJ22
1/28/2011 4:52:48 AM • Sony CLIE... • Answered on Jan 28, 2011
Stuck on screen
i got it! just take out the battery then put it back in!
4/10/2010 5:23:19 PM • Sony CLIE... • Answered on Apr 10, 2010
Wiil not turn on
hit the reset button
1/8/2010 3:16:09 PM • Sony CLIE... • Answered on Jan 08, 2010
2answers
I have not used my clie for a VERY long time. I
The manual is available here on Fixya for your handheld. I'm including a link to the page that discusses the on-screen keyboard, but once there you can flip back and forth through the rest of the manual at need. Hope it helps!
Manual
10/20/2009 10:39:33 AM • Sony CLIE... • Answered on Oct 20, 2009
I Have a Sony CLIE PEG-SJ22 that I want to get internet on!!!
Hey dude. You don't even have a built-in browser in that handheld. What use can it be of even if you can get wifi to work on it? In addition, this thing has a CPU clock speed as fast as a 80486 Intel desktop CPU, even if you can browse the internet, it will take forever to finish loading a page. Oh, do you know that it only has 16MB internal memory for everything? If you want to check email, use outlook or palm desktop to receive them and sync it to your Clie. This is the closest you can get to the internet with this handheld. Goog luck and don't forget to amaze me by posting a real solution up if you can find anything, I mean anything, better than what I just said.
8/26/2009 6:39:03 AM • Sony CLIE... • Answered on Aug 26, 2009
2answers
Clie PEG-SJ22 does not charge battery
Have you tried resetting the unit? There's a little button on the back that you can press in with a paper clip. That'll cause the unit to reset (you won't lose data) and then you might be good for charging.
8/7/2009 11:56:24 PM • Sony CLIE... • Answered on Aug 07, 2009
Screen Problem with my Sony CLIE PEG-SJSS
All you have to do is:
Look in the very bottom, right hand corner of the touchpad. You will see a little cog, click that and set it to whatever you want!
3/8/2009 2:54:25 PM • Sony CLIE... • Answered on Mar 08, 2009
How do I CLEAR everything on my Clie
Hard Reset CLIE Sony Series
  1. Connect the CLIE handheld using the AC adapter and take out the stylus pin by twisting the upper part of the stylus.
  2. Push down and hold the power button of the unit and use the stylus to slowly press and release the reset button on the back.
  3. When the Palm screen will appear release the power button.
  4. At the “Erase all data?” prompt, push the upper part of the scroll button on the front of the device to confirm OK. The Sony pda is now reset and you have only to follow the SetUp steps as prompted.
2/1/2009 4:01:40 AM • Sony CLIE... • Answered on Feb 01, 2009
Palm talp hasent working.
it was cleared by my friend.
1/28/2009 1:20:51 PM • Sony CLIE... • Answered on Jan 28, 2009
Not starting up I get nothing!
Press the power button and hit the up button to reset to start.
I have the same issue and my palm battery will not charge and stil working on it. Try line 1 first
2nd option remove the battery and try without it. Then put the battery back in.
Hope this helps
10/27/2008 6:49:43 PM • Sony CLIE... • Answered on Oct 27, 2008
TANSFER DATA from SONY CLIE SJ22 to HTC TYTN2
I'm in the process of changing from SJ22 to Smartphone running Windows Mobile 6.1 and I have found a way round this by sending data as vcard to myself in outlook then opening the attachment and saving and closing - this is then sent to your device on the next sync. It is a bit long winded but it works.
Open Outlook and leave it open.
In Palm, select the address you want to send, then in EDIT menu choose Forward as vcard, send and close the outlook pop up, saving changes.
Go to Outlook Inbox and open the attachment then save and close.
9/17/2008 6:14:40 PM • Sony CLIE... • Answered on Sep 17, 2008
Hot sync problems
Doe's some one out there have the software that came with the sony clie peg sj22/u
software version 1.1
5/3/2008 4:35:38 AM • Sony CLIE... • Answered on May 03, 2008
Sony Clie
I found there is an online tutorial which said to hold down the power button for a few seconds and the light comes back on.
4/3/2008 2:44:10 AM • Sony CLIE... • Answered on Apr 03, 2008
0answers
Sony CLIE PEG-SJ22 Handheld Logo
33 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CLIE Sony
  • CLIE Sony
Most Popular Question
hard reset
  • Computers & Internet
