20 Most Recent
Sony CLIE PEG-T615C Handheld Questions & Answers
My Clie PEG-T615C/G has worked
check that your files ( the address, datebook, todo and memo pad ) have not gone in "read only" mode. uncheck it and try again.
regards
4/15/2011 2:32:20 PM •
Sony CLIE...
Answered
on Apr 15, 2011
Hotsync Problem with Sony Clie PEG-T615C using XP SP3
Maybe you could also try updating Palm Desktop or maybe downgrading Palm Desktop because I have that exact same PDA and I know it's old. If neither of those work, just pull a system restore or whatever you had planned.
2/13/2010 4:35:34 AM •
Sony CLIE...
Answered
on Feb 13, 2010
Any way to get the cd for the sony PEG T615C to
Hello.
From FixYa Support:
Run the program in XP compatibility mode.
First install the Palm Desktop CD that came with the CLIE. Go
to "Start"> All Programs> Sony Handheld
1. Right click
"HotSync Manager" and click "Properties" click Compatibility tab and and check
"Run this program in compatibility mode for: Windows XP (Service Pack 2).
2. Then HotSync your CLIE it should work.
If it doesn't work:
1. While
installing software from the CD open the CD and Right-click setup.exe and check XP Compatibility, and while installing, if a pop-up appears for drivers, just Click
Use Old Drivers anyway.
2. In "Start"> All Programs>
Sony Handheld
Rightclick all the shortcuts like "Palm desktop for Clie", "Install
tool", "Hotsync manager" and set it to run in XP compatibility mode.
Hope this helps.
1/12/2010 4:02:48 AM •
Sony CLIE...
Answered
on Jan 12, 2010
I have a Clie SJ22/U and downloaded the Vista
I have a peg-615c, and I just downloaded the new palm desktop, and installed it AFTER I had switched the compatability mode to xp, and selected open as an admin on the normal screen, and under all users...
I works great now! OH, it's a free program :)
http://kb.palm.com/wps/portal/kb/common/article/37014_en.html
9/28/2009 1:52:25 AM •
Sony CLIE...
Answered
on Sep 28, 2009
Hotsync between vista and clie t615c
I could not sync my new Dell XPS with my t615c clie. Same error about not finding the com port.
I tried the solution about Xp compatability.. and still did not work.
I thought I would have to keep my XP PC and sync to there. But then my XP Pc did not sync either.
I did a soft reset from the hole in the back of T615C and then I could sync to the XP PC.
Then I thought maybe.. just maybe if the reset worked, I could sync to the Vista PC. YEAH!!!!!!.
It might have been a combination of making the check mark with the XP compatablity.. or just the reset button. But I am a happy camper now.
Life is simply sometimes...... IF YOU WORK AT IT!
1/1/2009 4:38:50 AM •
Sony CLIE...
Answered
on Jan 01, 2009
Vista will not recognize my Clie
Please install thePalm Desktop Operating System 6.0 or higher from any search engine or Palmzone.
This will resolve the issue.
Regards
Chris 2030
12/15/2008 6:36:59 PM •
Sony CLIE...
Answered
on Dec 15, 2008
Installing this PDA on Windows Vista Home Premium laptop
you shouldnt need a device driver for your pda to work along side with Vista, as Vista has it's own Windows mobile device centre which should run as soon as you connect your pda to a usb port.
If it doesnt run, then open up windows mobile device centre in programmes and check the mobile device settings as to whether usb is set to connect to the centre.
7/22/2008 2:41:45 AM •
Sony CLIE...
Answered
on Jul 22, 2008
