20 Most Recent Zebra Z6M Plus Thermal Label Printer Questions & Answers
sensor not working or dirty in the feed path id suggest
Zebra Z6M Plus... | Answered on Dec 27, 2017
You need to give more info.
Are you using labelling software?
Zebra Z6M Plus... | Answered on Feb 10, 2016
I would venture a guess that the sensor that detects the labels isn't working well - it's supposed to see the difference between label and backing paper and stop at the correct position.
Zebra Z6M Plus... | Answered on Feb 04, 2015
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Zebra Z6M Plus... | Answered on May 21, 2014
Z6M+ printer doesn't have USB port, how do you connect this printer to Win 7 PC? if you are using parallel / serial converter to USB then good luck. Ideally to get zebra external printserver and connect the printer through the network.
Zebra Z6M Plus... | Answered on Oct 21, 2013
The sensor on this printer is a double sensor. The side close to the frame is the head open and the one on the outside is the ribbon present. It is adjustable. They both reflect off the chrome surface of the head assy. above them. First clean the chrome surface above the sensor and test before adjusting. There is one screw that you can loose and tilt the sensor to match the angle of the chrome plate above. Also the gap between the sensor and the chrome surface is .060in. or 1.5mm.
Zebra Z6M Plus... | Answered on Jun 28, 2013
First clean the sensor tag and sensor head open and tape. Then perform a calibration label pressing the PAUSE and FEED buttons and turn on the printer, release the keys until it starts to move the label. Wait until you are finished and ready to print.
Welcome to FixYa.
Check the "Printing Properties" of the software you are using to print. The "scale to fit media" or an option to shrink the printout must have been turned on or checked. Depending on the software you are using to print, it is usually found at FILE > PRINT > Printing Properties.
Thank you for using FIxYa.
Zebra Z6M Plus... | Answered on Jan 05, 2012
Zebra Z6M Plus Thermal Label Printer Logo
52 questions posted
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Zebra
  • Z Zebra
Most Popular Question
z6m stop feeding
  • Office Equipment & Supplies
