20 Most Recent
RCA 32F531T 32" TV Questions & Answers
My Mitsubishi 1080 powers on but wont stay on
HiYou may have a problem in the power supply (a leaky componente) or an overload in the line supply that should be traced. Sometimes the line supply filter capacitor (47uF/250) dries up and the voltage raises and the overvoltage protection shuts down the set. This should be traced paciently.Sully
Wont turn on after menu pda locked,even after
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
- Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
- Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Ok.
How to unlock RCA 32F531T 32 '' tv. I tried the manual solution but didn't work.
You might have to enter its service mode option to unlock it.
Visit the site named 'Electro-help' for
more details. Check this link and
select the site named above. View it
in 'Flip card' option, which can be
selected from the drop down box menu at the left top corner or the display
window. It will make search easy. Some times, the ads attached with each posts
might help you to find the availability of spare parts. There are more than 580
posts to different brand TVs.
Unlocking my Model 32f531t television without a remote
rca32f531t
to reset parental password : turn off tv / simultaneously press and hold volume - on the
front panel and clear on the remote for 5 seconds
then just enter a new password next time your in the parental menu
so you will need the remote to do this
electech
How do you unlock 27
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help
