20 Most Recent RCA TruFlat 27F520T 27" TV Questions & Answers
TV turns on, then immediately off again
The flyback transformer are damaged.
7/3/2022 12:27:18 PM • RCA TruFlat ... • Answered on Jul 03, 2022
2answers
Unlock truflat tv without remote?
ok this totally stressed me out but I figured it out and my TV is ON!! I purchased a really cheap universal remote at a .99 cent store. Sat in front of the TV and followed the directions on the manual for my new remote, keep in mind there was a red light lit on the TV, when all directions on connecting the remote with the TV were complete I pressed on and the TV turned on. I hope this helps!!!!!
2/20/2021 5:58:41 PM • RCA TruFlat ... • Answered on Feb 20, 2021
Manual for quantum FX rem 126 universal remote
Where is the setup button on the universal remote
2/18/2021 12:41:27 AM • RCA TruFlat ... • Answered on Feb 18, 2021
2answers
2answers
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver. All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear. Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off. Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
5/9/2019 1:20:01 AM • RCA TruFlat ... • Answered on May 09, 2019
2answers
The TV is blocking certain
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
11/6/2018 11:37:42 AM • RCA TruFlat ... • Answered on Nov 06, 2018
My fpa lock is on
I just did this on my tv same exact model, I used a universal remote, it was an rca remote but im not sure it makes a difference. I programmed the remote to this tv with the tv off and it worked. the programming directions say to turn the tv on but i couldnt. If and when u get the tv on if u are using a universal remote get the menu up. most likely the light will be flashing. take the battery out and put it right back in. the light should no longer be flashing, and the menu should still be up. u can now navigate to the preferences and turn off the fpa lock... good luck
6/11/2018 6:36:54 PM • RCA TruFlat ... • Answered on Jun 11, 2018
I have a (RCA) TV and theres a parental control
Try this...turn off the television, then press the "Volume Down" button on the TV and the "Clear" button on the remote at the same time. Press them both for five seconds, then release and turn on the TV. When it's time to enter your parental password, the system should ask you to reset it. If you need to reset other settings such as picture quality or brightness, look for an "All Reset" option under the "Setup" or "Others" menus. Selecting this option returns all the settings to their factory defaults.
2/11/2018 5:34:58 PM • RCA TruFlat ... • Answered on Feb 11, 2018
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote. Look around the tv and find the menu button. Generally there is a separate power button. You can also download the manual: http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
12/2/2017 10:02:10 PM • RCA TruFlat ... • Answered on Dec 02, 2017
2answers
How to hard reset rca 27F554T
The means the deflection is not working, there is a coil of wire around the neck of the tube, it is run by a transistor. This transistor has probably gone bad
11/24/2017 3:10:57 AM • RCA TruFlat ... • Answered on Nov 24, 2017
MI TV SE APAGA AL ENCENDERLA Y YA NO QUIERE PRENDER BIEN...
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
7/12/2017 8:12:31 AM • RCA TruFlat ... • Answered on Jul 12, 2017
TV turns off when you change the channel
sounds like a power fault, prob just weak capacitors if you can change them it would not cost a lot to replace them, when you change channel it draws more power and if its at its limit it will turn off as the capacitors cannot take it. few £'s or $s to get the replacement capacitors, you will probably see the blown capacitors on the power board as the will not have flat tops they will be rounded, change them same for same i.e 16v 330 for same 105c type would be best. it will say this on the capacitor.
5/27/2017 8:49:50 AM • RCA TruFlat ... • Answered on May 27, 2017
RCA TV MODEL L46FHD37RYX7 NEED CODE TO PROGRAM TO MY REMOTE NONONE OF THE RCA CODES WORK
How to get the Spanish. To go to English
5/3/2017 11:31:57 PM • RCA TruFlat ... • Answered on May 03, 2017
I have an RCA truflat
Make and model of the cable box?
3/30/2017 2:35:08 AM • RCA TruFlat ... • Answered on Mar 30, 2017
29 inc flat tv flickering
maybe your tv screen has a problem much better if you bring it to a tv technician.
3/1/2017 1:16:59 PM • RCA TruFlat ... • Answered on Mar 01, 2017
My Parental Lock has spontaneously activated on only one channel (4). No reset method seems to work, partly because I only have a satellite remote, not the original TV, and numbers don't input.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
7/22/2016 12:02:55 PM • RCA TruFlat ... • Answered on Jul 22, 2016
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
6/4/2016 12:57:58 AM • RCA TruFlat ... • Answered on Jun 04, 2016
1,003 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
turn off fpa lock without remote
  • Televison & Video
