20 Most Recent
Brother Se425 Computerized Embroidery & Sewing Machine Questions & Answers
Brother se425 feed dogs will not move
they need to be checked, may need to be timed or replaced, could also be a problem with the hook and hook race. or see if the feed dogs are in the up position to sew, in the down position is for darning.
My brother exedra e-40 #db2-b737-413
- In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
Brother XL5600 is not stitching properly and dropping stitches?
need to check the hook timing.
put it in zig zag, no fabric, turn the hand wheel to you slowly.
check the needle when it is coming back up, is the hook picking up the thread? if yes continue to check the next side, so if you check the left side then check the right. if any side its not picking up the thread then the timing is off and need to be retimed
