20 Most Recent
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Questions & Answers
Motherboard is fried, what can
Try website like Tvrepairworld.com,Ebay.com to buy a refurbish mother board,they might have it.Don't it time to buy and replaced for a LCD tv better tv over all as a tv and for buying for replacement parts later for replacement for tv needed parts later on as LCD tv needed circuit board for parts.
Replace fuse fl231
It will be best to contact any service technician. We can't predict, what might have been happened due to lightning stroke.
Color changing
youve most likely got an issue with the CRTs one most likely which cuts out and back in randomly. Try removing the rear cover and look in at the three crts while its doing that and see if you can see one or more keep turning off and on.
How do I clean the inside of the screen?
Don't even try to clean the inside of the screen on the mode indicated here, av 56p575.If the picture is darker remove rear cover and reach up with a lens cloth and clean the three large lens---they are your light source.What is your reason to want to clean the inside of the screen, I am able to offer advice there.
I have a jvc AV-56P575,
The CC is activated or disabled only from the remote - there is no option for that in the menu, in there you can only select what kind of CC you want to use (as you have yourself discovered).
The CC button is - on the original remote - right below the power button: press it once to disable CC.
