20 Most Recent Clymer Evinrude/johnson Manual 2 Stroke Ob 2 70 Hp,18 35 Jet Drive 95 03 Questions & Answers
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
1/2/2015 7:31:42 PM • Clymer... • Answered on Jan 02, 2015
55973 A EVINRUDE Wiring Diagram IN COLOR FOR Free
Red battery positive Red purple, switched positive Yellow red startermotor connect to positive to start ) Purple white choke (connect to positive to choke) Black yellow stop circuit ( connect to negative to stop engine ) Black battery negative ( for stop circuit )
10/4/2017 7:00:50 AM • Clymer Boating • Answered on Oct 04, 2017
Yamaha 25 nmo
The power supply is common for all the coils. Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil. If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
10/4/2017 6:46:16 AM • Clymer Boating • Answered on Oct 04, 2017
I have an Evinrude jet drive outboard motor that
I think you have to look at a fuel supply problem. Clogged carbs or bad fuel pump... Also have a look at your spark plugs...
9/25/2017 1:47:53 PM • Clymer Boating • Answered on Sep 25, 2017
Outboard 115 yamaha misfiring at low revs
clean carbs and check set up !
6/4/2014 11:29:30 AM • Clymer Boating • Answered on Jun 04, 2014
3answers
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM • Boating • Answered on Dec 05, 2023
4answers
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin Cruisers are 20-40 feet. There are of course larger Yachts that can get to over 100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM • Boating • Answered on Nov 15, 2023
Diesel Boat motor cuts out under increased revs
I would clean the fuel filters and empty the water retainer filter then do some testing.
11/7/2023 9:11:35 AM • Boating • Answered on Nov 07, 2023
2017 Tracker 17.5 ft. boat. How can I remove batteries from it please.
Question edited for clarity. Question moved to Boating. Hello Anonymous Harriet :>D You will have two or possibly 3 batteries. Usually a large car type starting battery for starting the engine. Then two Deep Cycle Gel Batteries, one for the marine electronics, fish finder etc, and another that powers the front bow mounted Trolling motor. You will find them in the deck lockers. Open them, release any tie downs, undo the cables and lift them out for Winter storage. I keep mine in my garage and I put them on a battery minder for 24 hours once a month. I have the Battery Tender Junior, and I put them on a 6 amp car charger before the season starts. https://www.google.com/search?q=Battery+Tender https://www.google.com/search?q=2017+tracker+175+remove+battery The information you gave is is merely the year of manufacture, the maker and the length. They all have model numbers. That would be the key to searching for a manual online. https://www.jdpower.com/boats/2017/tracker-marine/pro-guide-v-175-wt__/32067137/specs and https://www.bbcboards.net/showthread.php?t=969900 ..
11/4/2023 10:54:05 PM • Boating • Answered on Nov 04, 2023
2017 Tracker 175 boat. Owners manual for it please?
Question edited for clarity. Question moved from Cars and Trucks to Boating. They don't list Manuals, but they should link you to one in their archive.
TRACKER Boats Learning Center
Tracker Boats https://www.trackerboats.com > learning-center PRO GUIDE V-175 WT · TARGA V-18 WT · TARGA V-19 WT · Jon Boats · GRIZZLY 1648 JON ... Owners. Warranty Information · Warranty Claim · Warranty Transfer · Order ...
11/4/2023 10:33:35 PM • Boating • Answered on Nov 04, 2023
Overheating on 150 Susuki outboard motor.
check water flow pump fail -corrosion--debris blockage---check fluids--gear oil etc
10/18/2023 12:53:27 AM • Boating • Answered on Oct 18, 2023
Yanmar 4BY2 with 1000 hours overheats when run above 2000 rpm - this is new, she cruises at 3500 rpm all day when running OK. Loses 1 gal water in 5 min at 3200 rpm. No visible leaks, smoke.
Commonly caused by clogged air filter. Also suspect buildup in exhaust mixing elbow. Smoke will build up carbon deposits over time and clog them. What color is the smoke? unburnt fuel will smoke and cause heat. Could be a fuel pump or dirty/bad injector not atomizing fuel correctly. If smoke is steam.... If there isn't proper flow or there is air in raw water system, the air hits heat exchanger and immediately turns to steam. Will result in overheating.
10/17/2023 10:48:57 PM • Boating • Answered on Oct 17, 2023
My 40 hp mer user.40elptefi dies if not connected to battery
It's electronic fuel injection so it needs power to run. Mercury is usually a yellow wire from stator that goes to a voltage regulator that charges battery when running. Good luck!!
10/17/2023 10:35:57 PM • Boating • Answered on Oct 17, 2023
I have a 37 ft Cruisers with T-D6-370-
def check fuel filters and air filters. Is it smoking when powered up? If so, what color is smoke?
10/17/2023 10:31:15 PM • Boating • Answered on Oct 17, 2023
Bilge pump and float wiring 242 cr
check continuity on float switch to assure it's working. image 10-17-23 at 18.24-undefined-undefined-1.jpeg do you have it wired like this?
10/17/2023 10:25:48 PM • Boating • Answered on Oct 17, 2023
2answers
What is the most expensive yacht in the world?
Off-course There are so many companies who are offering expensive yacht charter for rent in and around Europe. I suggest you to enter Kavas is the only yacht chartering company in Greece with over 25 years of experience in our industry. Kavas is offering all range from reasonable to luxury yacht services in Athens, Kos Island and Lefkas Island. For more details visit Bareboat or Crewed Yacht Charters in Greece
10/13/2023 4:52:02 PM • Boating • Answered on Oct 13, 2023
Clymer Evinrude/johnson Manual 2 Stroke Ob 2 70 Hp,18 35 Jet Drive 95 03 Logo
1 questions posted
Top Clymer Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
year model serial number
  • Boating
