20 Most Recent Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732 Questions & Answers
Adampeake how do you download free from the web link
they wanted $19.99USD
Clymer... | Answered on Apr 20, 2019
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Clymer... | Answered on Dec 13, 2014
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Clymer Boating | Answered on Oct 04, 2017
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
I think you have to look at a fuel supply problem. Clogged carbs or bad fuel pump...
Also have a look at your spark plugs...
Clymer Boating | Answered on Sep 25, 2017
clean carbs and check set up !
Clymer Boating | Answered on Jun 04, 2014
Probably early 80's. See this chart. I didn't see your number but the 695-310..... was in the early 80's.
http://www.auto-repair-manuals.com/25-30.html
Boating | Answered 2 days ago
Maximum weight is 1171 pounds or 7 persons. 200hp is the maximum on the 196.
All the specs are in the PDF in the links
[PDF]
pro series - Princecraft
https://www.princecraft.com/openfile.aspx?file=ArchivePdf-34en-US.pdf
Pro 169 BT, 169 LX SC & 179 LX SC 28-29 .... Super Pro 196 & 220 Platinum Series ... SP 196. SP 220. SPECIFICATIONS. Center line. Beam. Bottom width. [PDF]
specifications - Princecraft
https://www.princecraft.com/openfile.aspx?file=ArchivePdf-38en-US.pdf
weight person cap. Max. person cap. Bottom. Side. Hudson DLX SC. 5.9 m. (19'-4"). 2.2 m .... Utility Series. Fishing Fun ...... PRO FISHING SERIES. 207 SE3.
Boating | Answered 3 days ago
Common changes involve a new connector that fits the unit and splicing in the old cable. If the old cable is 10+ years old, I would replace it.
There is a model 60452 listed under 60hp, 1964year. Not sure what the S means, but in the 60's they were 2 cycle. I don't think 4 cycle came out until the 80's. Evinrude Outboard Motor Model Numbers
Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732 Logo
4 questions posted
Top Clymer Boating Experts
Colin Stickland
Colin Stickland
yungtek
Level 1 Expert
Bruce
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
115 johnson moor spits sputters when
  • Boating
