20 Most Recent Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP Questions & Answers
You should find a sticker in the front of the engine.
But usually you're ok with a 50/1 fuel oil ratio.
Clymer... | Answered on Oct 04, 2017
I don't have the diagram here, but it should be mainly color on color.
I'll look for a diagram if you couldn't get out.
Have a mix of 1.5%.
Disconnect and plug the oil pump connections at the VRO.
Unplug the wiring at the VRO.
Disconnect the VRO and tank alarms.
Have you checked the oil quantity AND quality in your drive?
You can drain the gearbox by removing the lower drain plug and the filler plug on the drive.
It's possibily full of water and your drive just seize when hot...
Clymer... | Answered on Sep 25, 2017
Check the idle mixture. Sounds to me like it is too lean.
Clymer... | Answered on Mar 20, 2017
yes
service
water pump checked over
was it stored off the boat
if attached to an aluminum hull (electrolysis )
check over for corrosion internal and all wiring connections
in any water jackets or intakes ..mud wasp nests
or rodents
Clymer... | Answered on Mar 08, 2017
Engine # MAY be the same. Should be top of crankcase.
Clymer... | Answered on Mar 02, 2017
could be any number of things . is the kill cord in place , do you have spark , is it getting fuel to carb ,
Clymer... | Answered on Sep 04, 2015
An evinrude dealer may be able to help you
Clymer... | Answered on Feb 22, 2015
There should be two hot wires one from the battery and one from the switch the one from the switch check should be hot when the key is held on the start if it is the starter solenoid is bad
A Evinrude 4BRCI is a 1981 4 HP 2 stroke Short shaft 15"
barbosam08.jpgbarbosam08_0.jpgbarbosam08_1.jpg These are specific to that motor.
Clymer... | Answered on Nov 22, 2014
1986 Just google the model and parts diagrams are available
Clymer... | Answered on Nov 06, 2014
What year is my Kiekhefer Mercury Outboard SN 389664, Mdl-KF-7
Clymer... | Answered on Oct 07, 2014
Check fuel lines and breather on tank
Clymer... | Answered on Sep 20, 2014
2stoke engine no less than 100psi !
4stroke the same but not a critical !
which engine have you ??
Clymer... | Answered on Sep 15, 2014
I have had ones that I had to drill out,the centre of the pin rusts and ends up being larger than the hole,not an easy job
Clymer... | Answered on Aug 18, 2014
Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP Logo
Popular Tags
133 questions posted
Top Clymer Boating Experts
Colin Stickland
Colin Stickland
yungtek
Level 1 Expert
Bruce
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
yamaha 100hp 4 stroke full service
  • Boating
