20 Most Recent Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards Questions & Answers
115 yamaha sho vmax over 3500 rpm it reves up and down under 2400 it stays even rpm. 2017 yr.
If your 115 Yamaha SHO VMAX outboard engine is experiencing RPM fluctuations at speeds over 3500 RPM, it may be due to a few different factors. Here are some things to check:
  1. Fuel supply: Make sure that the fuel supply to the engine is consistent and free from any debris or obstructions. Check the fuel filters, fuel lines, and fuel pump for any signs of damage or clogging.
  2. Spark plugs: Check the spark plugs to make sure they are clean and functioning properly. If the spark plugs are worn or dirty, they may cause the engine to misfire at higher RPMs.
  3. Throttle position sensor: The throttle position sensor (TPS) sends a signal to the engine control module (ECM) to adjust the fuel and air mixture. If the TPS is not functioning correctly, it may cause the engine to fluctuate at higher RPMs.
  4. Air intake system: Make sure that the air intake system is clean and free from any debris or obstructions. Check the air filter and air intake hoses for any signs of damage or clogging.
  5. ECM software updates: Check with your Yamaha dealer to see if there are any available software updates for the ECM that may improve the engine's performance.
If you are unable to diagnose and fix the issue on your own, it may be necessary to take the engine to a professional technician for further diagnosis and repair.
2/24/2023 1:57:40 PM • Clymer Marine... • Answered on Feb 24, 2023
2answers
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
6/26/2022 3:42:09 AM • Clymer Marine... • Answered on Jun 26, 2022
1998 yamaha 225hp ox66 starts to plane off dies down losing spark
You might have a magnet issue(under the flywheel).. it happened to me.. one was loose..
11/12/2021 4:59:24 PM • Clymer Marine... • Answered on Nov 12, 2021
Mariner 9.9 outboard 2 stroke owners manual
do and online search and include year --
10/5/2021 4:45:07 PM • Clymer Marine... • Answered on Oct 05, 2021
Free outboard repair manuals
very basic carbs ! clean all jets and emulsion tube then check the float needle is clean and the tip isnt grooved , blow threw all ports etc and then refit and set the mix screw 1.5 turns out for starters then run up in a tub of water and fine tune till its happy to idle and rev up ! make of engine ??
4/20/2019 9:11:10 AM • Clymer Marine... • Answered on Apr 20, 2019
Yamaha 25hp 4 stroke stator Installed new one and it went bad in one day why
Check your battery wires. If the battery disconnects even for one second or the grounds are bad then the stator has no where to put the charge and it will fry.
8/25/2018 12:26:37 AM • Clymer Marine... • Answered on Aug 25, 2018
What trim sending unit is on 2005 Yamaha 150 vmax
67H-83672-00-00 All models uses the same unit since 2004 ( from 30 to 300hp)
11/14/2017 9:29:22 PM • Clymer Marine... • Answered on Nov 14, 2017
2002 90hp yamaha 2stroke i replaced the ten pin electric harness.i installed new remote control.but i have analog gauges. how do i connect to them . the six pin does not match up
Hello, you'll need a second wire harness for the instruments. And also a hose for the speedometer.
10/4/2017 9:20:18 PM • Clymer Marine... • Answered on Oct 04, 2017
Outboard 115 yamaha misfiring at low revs
Unscrew the 4 idle mixture screws 1/2 turn 1 at the time till sneezing stops... Clean your carburettors
10/4/2017 7:01:44 AM • Clymer Marine... • Answered on Oct 04, 2017
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized... Remove the recoil starter ( 3 bolts and the startingear link) If you can turn the flywheel slightly: Gearcase seized If you can't turn the flywheel at all: Engine seized. In both cases: If you can't disassemble and have the job done yourself, forget that motor...
10/4/2017 6:54:57 AM • Clymer Marine... • Answered on Oct 04, 2017
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side. With an airgun, blow in the check hole from outside to engine side. With an airgun, blow out the engine connection. Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint. If still no water at the engine connection: replace the impeller!
10/4/2017 6:50:01 AM • Clymer Marine... • Answered on Oct 04, 2017
Yamaha 40 hmo
Nice engine
10/4/2017 6:36:49 AM • Clymer Marine... • Answered on Oct 04, 2017
Yamaha 4 hp outboard steering friction swivel screw does not work
That's a current problem. OR the screw is rusted in place. So then use WD40 or eqivalent to free the screw. Or the parts inside are worn. Remove the friction screw. Then, remove the 4 bolts holding the swivel cap. Remove the entire engine from the swivel to prevent it fall on the ground. Replace the worn parts.
10/4/2017 6:36:24 AM • Clymer Marine... • Answered on Oct 04, 2017
Free Repair service manual for 15D 684C outboard required
Have you checked manualslib.com?
10/4/2017 6:33:32 AM • Clymer Marine... • Answered on Oct 04, 2017
Spark plugs for 2005 Yamaha vmax 150 hp
BR7HS-10 (1mm gap)
9/25/2017 10:26:55 AM • Clymer Marine... • Answered on Sep 25, 2017
2000 200hp ox66 yamaha outboard has issue with losing power after getting on plane. It drops about 10 rpms at a time until you back down to idle and runs smooth. Throttle back up and issue returns.
Sounds like it has a fuel restriction. Hook up a fuel pressure gauge on the vst tank on the motor to make sure you have 30-50 lbs of fuel pressure.
8/20/2017 4:13:21 AM • Clymer Marine... • Answered on Aug 20, 2017
Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards Logo
Popular Tags
87 questions posted
Top Clymer Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
mariner 9 9 outboard 2 stroke owners
  • Boating
