20 Most Recent SkyScan 86742 Digital Atomic Wall Clock Questions & Answers
2answers
My solar clock needs setting. I set it back an
1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
4) Press and HOLD the "set" button down untill the hours digits start to flash2.gif.
5) Now press the "set" button again six times. The time zone characters will flash.
6) Press the "adjust" button untill your time zone appears.
7) Press the "mode" button to return the clock to normal operation.
8) Press the "adjust" button to display the day-of-week.
11/9/2022 2:08:59 PM • SkyScan 86742... • Answered on Nov 09, 2022
Have a skyscan clock and the the time will not set
If you're down in hole, or if the signal is somehow otherwise blocked, the clock may never sync with WWVB. Otherwise, you need to try it in different locations and facing in different directions. Some folks place the clock outside once a week or so, and face it towards Colorado to pick up the signal.
Bill B
7/23/2019 3:11:17 PM • SkyScan 86742... • Answered on Jul 23, 2019
Cant fix the time zone
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
5/2/2016 5:19:28 PM • SkyScan 86742... • Answered on May 02, 2016
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
10/21/2014 5:09:54 AM • SkyScan 86742... • Answered on Oct 21, 2014
0answers
WHERE DO I FIND MY SOLUTION THAT YOU SOLVED AND I CLICKED TO POST IT
Which question was your original question?
5/31/2014 2:12:00 AM • SkyScan 86742... • Answered on May 31, 2014
I have a skyscan atomic clock that went haywire after dst I can't set the clock date or temp. What can I do buy a new one?
Remove battery for a minute, reinsert battery and allow clock to settle (15 min) now try.
4/28/2014 1:30:13 AM • SkyScan 86742... • Answered on Apr 28, 2014
0answers
SkyScan 86742 Digital Atomic Wall Clock Logo
149 questions posted
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
View Most Popular
SkyScan Home
  • SkyScan Home
Most Popular Question
repair fantazein clock
  • Home
