20 Most Recent
Rangemaster Professional 110 (Duel Fuel) Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
I've a dual fuel 1100 rangemaster professional-
this condensation. and your cooker is removing the moisture in the air in the room. this if not fixed will rust your cooker from the inside out , you will need to fit an extractor fan to your room or if one already fitted get a larger one. or use a dehumidifier
We had a power cut and can now not get either oven
it is the timer. i take it that the display is blinking and no current time is seen? hold the 2 buttons on the left down together for a few secs, now the display will show 12:00 set it to the true time and you are good to go
Fan oven element not working
getting a shock just means that live is connected. if no heat, that means that no neutral assuming element is ok. do you have a multimeter so you can check if live and neutral present at element? are you sure old element was faulty as it seems strange that putting in a new element did not cure problem
i have a memory that there may be a fan fail stat mounted close to the element. worth a check
I have a Rangemaster Classic 90 dual fuel that has problems igniting the gas hob.
Remove the flame spreaders and rings from the 3 rings you use the most, including the faulty one. Put them in a large pan cold water, add a teaspoon of dish liquid and slowly bring to a simmer. As soon as it want to boil over, blow on it and turn the heat off. Leave it to cool. Scrub with a plastic pot brush making particular attention to the holes. You had a blocked one which is the one that directs the gas to the spark igniter. Rinse and dry them, and replace to the hobs.
Rangemaster LPG conversion?
If the LPG cylinders have the correct pressure regulator, no need to use an extra one but any regulator must be set to the correct pressure or removed.
