20 Most Recent
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Questions & Answers
New coil for chainsaw
the coil is on the flywheel side of unit. remove the recoil cover and you will see the flywheel and coil. your have to remove the ground wire from shut off switch and two bolts holding coil in place. when installing new coil you need to leave a 10 thousand air gap between the coil leg and the flywheel magnet for proper operation
Not getting spark to the
Try a new condenser. They are very cheap and can freeze which shorts it out inside so the magneto energy is not absorbed and ready for when the points fire. It only has one wire and looks like a metal cylinder about 1/2" diameter.
Trigger wire that goes to the carb is not working.
There should be a safety bad on ths handle that you hold down so that you can pull the throttle trigger. Check to make sure you are depressing it enough or that it is actually unlocking when depressed.
It's about Husqvarna 345 chainsaw.
The easiest way to test is on the machine. Remove the ignition switch wire from the module coil. Check the pole gaps of the module by inserting a thin business card into the gaps after turning the flywheel magnets under the module. Loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel slightly to release the card. Turn the flywheel one full turn to make sure the gaps don't close up further. Use a fresh spark plug gapped at 0.020" and try for spark. If nothing, replace the module. This gets around measuring resistances while trying to evaluate the module. Hope this helps!
Fuel/oil mixture ratio huskvarna 350
With Husqvarna two stroke oil it should run at 50-1, with other two stroke oil run it at 25-1 as we do not know the quaility of other oils, always try to use Husqvarna oil.
What type of oil should I use?
Hi Nick Ciulie.You will use any good brand of 2 cycle oil mixed with your gasoline if it is a 2 cycle engine.If it is a 4 cycle engine use a good grade of 30 weight non detergent oil.If the oil is for the bar and chain...use a bar and chain oil available from most auto parts supply houses.Please rate meBud
