20 Most Recent
Ranger RCI-6300F-25 CB Radio Questions & Answers
Ranger 6300F25drifts off frequency after warm up
buy some mr.freeze and spray some in the pll area to see if it drifts back on frequency. once you have determined that take it to a tech and let him know what you did and he will fix it.
2/23/2015 7:11:15 PM •
Ranger...
Answered
on Feb 23, 2015
When turned on, freq is
where did you get this radio? on ebay? this radio needs a lot of work by a tech not some golden screwdriver .
2/23/2015 6:45:48 PM •
Ranger...
Answered
on Feb 23, 2015
2950 RCI WONT TURN ON ONLY A BACKGROUND LIGHT
You either have a bad LCD display OR the connection for the LCD display is loose/off. Its impossible to tell what channel you are on with a 2950 without the screen working, but when you turn the channel knob do you hear any other cb transmitting on ANY channel?? This is a tough one!! I really need some more info on the radio.
Open the case and look at the area that the display is in (front of radio). Slightly wiggle all of the little plugs in that area. If you see the LCD screen come on or flash then you know where your problem lies. If not, then you're probably looking at buying a LCD display for the radio.
Good luck.
2/18/2011 2:47:40 AM •
Ranger...
Answered
on Feb 18, 2011
Hello when keying up after a few seconds I get a
Hi my name is John. Welcome to FixYa. You need to ground it to the negative (-) on the battery also. May be this will solve your problem. Let me know. Thanks for choosing FixYa....John
12/1/2010 12:12:15 AM •
Ranger...
Answered
on Dec 01, 2010
I have a 6 wire D104 . How do I wire it to a Ranger 2985 dx ?
Wiring a 6-wire D104 microphone to a Ranger 2985 DX requires connecting the wires in the correct order and configuration.
The Ranger 2985 DX has an 8-pin modular plug, and the D104 microphone has a 6-pin modular plug.
Here's one way to wire the D104 microphone to the Ranger 2985 DX:
- Connect the red wire from the D104 to the 8-pin modular plug's pin 4 (PTT - Push-To-Talk).
- Connect the black wire from the D104 to the 8-pin modular plug's pin 5 (Ground).
- Connect the white wire from the D104 to the 8-pin modular plug's pin 6 (MIC + Audio).
- Connect the blue wire from the D104 to the 8-pin modular plug's pin 7 (Receive Audio)
- Connect the green wire from the D104 to the 8-pin modular plug pin 8 (Transmit Audio)
- Connect the yellow wire from the D104 to the 8-pin modular plug's pin 3 (UP-Down).
It's important to double-check the wiring configuration with the user manual of the Ranger 2985 DX and the D104 microphone. Some manufacturers have different wiring configurations and it's important to match the wiring accordingly to avoid any damage to the device.
It's also worth noting that if you are not comfortable with the wiring process, it's best to consult with a professional technician or a radio expert.
Led display
Hi John,Ranger CB YES, Model No. NO, led display, YES IT HAS ONE OF THOSE.More info please john.The more info about the radio you give and the problem, the easier it is to give you assistance, we can't answer buy guess work, it's neither helpful nor pleasant.Cheers,Peter
