20 Most Recent Ranger RCI-2995DX Base Scanner Questions & Answers
Check the fuse. Blowing a power supply does not happen. Blowing a fuse often does. If the power supply truly went out, it is too small in amperage. More information on the power supply may help.
Ranger... | Answered on Feb 02, 2018
http://www.cbtricks.com/radios/rci/rci_2995dx/index.htm
Ranger... | Answered on Jun 07, 2015
Generally, high SWR relates to an antenna problem. It could be as simple as the coax connector isn't tight enough. You could have damage to the coax cable, or the antenna may be damaged due to wind, or water in it. If you have access to an antenna analyzer, it will help you troubleshoot your antenna and coax, if not, start with a thorough visual inspection, looking for damage, cracking, or water infiltration.
Ranger... | Answered on May 01, 2014
no you don't
Ranger... | Answered on Feb 19, 2014
Have you checked the aerial? (antenna) often a power loss is due to problems in the plugs cables etc or high swr.
Ranger... | Answered on Feb 09, 2014
Please Re-post in the correct forum. This is for cell phones.
Ranger... | Answered on Oct 19, 2013
You put it on the CPU board, its called a (E-CHIP) if yours did not come with one, may be hard to find...You have to have a good steady soldering hand to do it. Have not done any of these, but did a few 2900 DX. ... hope this was helpful...
Ranger... | Answered on Oct 20, 2012
  • Hope this helps.
Regards, Tony
Ranger... | Answered on Oct 17, 2011
those mics are supposed to work for most radios ,,,if your getting good audio reports,,i wouldnt worry about it ,,im thinking of getting one for my icom 735 radio,,how much did u pay and where did u get it,,,,if you are worried about damaging your radio,,get a hold of ranger ,,and ask them about the mic
trevor berg
Ranger... | Answered on Sep 30, 2011
If you still have the D&A's let me know at dorn@dws-inc.com
Ranger... | Answered on Jun 11, 2011
Adj VR1 next to VR2 they are in the center of the main motherboard. VR1 will allow you to adj the S meter in AM mode only.
Ranger... | Answered on Apr 26, 2011
ITS JUST NOT THE TURNER MIC IT HAPPENS WITH ALL BASE MICS HAVE HAD THE SAME PROBLEM WITH MY 2995DX WITH A ASTATIC D-104 & 1104-C AND ALSO ANY TURNER I HAVE USED BUT I CAN RUN A ASTATIC MOBILE D-104M6B OR RED DEVIL AND NO SQUEAL HAVE YOU TRIED GROUNDING THE CASE OF THE RADIO IT IS RF FEED BACK SQUEAL SO MY SUGGESTION TO YOU IS TO RUN A 48 COPPER GROUND ROD INTO THE GROUND AND RUN A NICE GROUND WIRE TO THE BACK OR THE CHASIS OF THE RADIO AND IF YOU ARE USING ANY EXTERNAL AMPLIFIERS ALSO GROUND THEM AND YOUR SQUEAL WILL BE ILLMINATED
Ranger... | Answered on Mar 14, 2011
I just bought one and it came with a adatptor in heat shrink
Ranger... | Answered on Feb 06, 2011
Hi, my name is John. Welcome to FixYa. Turn your MICGAIN down a little, or if you have a modulating mic, turn it down. Thanks for choosing FixYa...John
Ranger... | Answered on Jan 25, 2011
Ranger Parts and Service is in California. (760) 440-0125
Ranger RCI-2995DX Base Scanner Logo
Popular Tags
42 questions posted
Top Ranger Radio Communications Experts
Mike Charette
normis101
Robert McClure
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Ranger Radio Communications
Most Popular Question
signal meter lazy
  • Radio Communications
