20 Most Recent Ranger TR-696F SSB CB Radio Questions & Answers
think cheap.first change the mic to see if that makes a difference. If it does you now have a new mic and a radio that works.Now it gets a little more expensive. you have to open the radio so the components show . Now ask yourself which one does what ? I know you can't answer it because if you could you wouldn't have posted this. I can tell you that its in your audio circuit . Now take it to a tech and have them fix it.
Ranger TR-696F... | Answered on Feb 23, 2015
check the obvious first. Is the mic plugged in and tightened all the way. Yes , take the bottom cover off and turn up the variable closest to the small transformer. Thats the modulation variable and the modulation transformer. If you still have a problem take it to a tech and let him fix it .
I'll take it. just ship it to me .
Ranger TR-696F... | Answered on Oct 30, 2013
This is not normal. Either you are magnetic, or you have some kind of RF reflecting off you. Or something like that. This is strange to me.
Ranger TR-696F... | Answered on Aug 01, 2011
adjust L20 (AM) L21 (USB) L22(LSB)
Ranger TR-696F... | Answered on Jul 03, 2011
hello what seems to be the problem can you be more exact
Ranger TR-696F... | Answered on Mar 26, 2011
is the meter good?
Ranger TR-696F... | Answered on May 01, 2010
If you have no channel display or CB operation, it sounds like a blown voltage regulator that supplies power to the CB PLL circuit.
Ranger TR-696F... | Answered on Sep 26, 2008
If you are using the radio on a boat, then no, the grounding does not matter that much. However, an SSB transceiver would be hassle to install on a boat because of the amount of power they use to transmit. If the transmission is bad, try using the radio's internal tuner instead of the separate tuner. This may help improve the quality of transmit, however, some radios have a tough time clarifying incoming and outgoing signals and create a garbled sound when it receives a signal or when it transmits. If that doesn't work, then you can try grounding. But if you want a radio that doesn't require all this nonsense tning, you might want to think about investing in a Yaesu. They are pricey, but are one of the best HAM radios.
Ranger TR-696F... | Answered on Sep 07, 2008
check out the schematic first .It may be the same wiring .
Ranger Radio... | Answered on Oct 03, 2018
Your radio needs an alignment to bring it back to specs . Check all the frequencies according to the manual and have a tech tune it for you .
If you want to talk on AM put it on AM if you want to talk on SSB then put it on SSB. Did you recently purchase this radio? You do realize you need a ham radio license to use this ?If you are on the upper ham bands you better have a license or they will come and get you .Look at the the dial that has 1 - 7 on it. Now take the owners manual and look at the diagram of the knob . It should say something about frequencies and the frequency you need to operate on is from 26.965 to 27.405 MHZ .
Ranger Radio... | Answered on May 06, 2016
on the back of the cpu behind the frequency counter display. you will see the pins sticking out
Ranger Radio... | Answered on Jan 10, 2016
The + side of the cell is smooth on the top (no seam), and the - side has a seam going all the way around it as shown below:
This side ^ is (+) and this side ^ is (-)
Ranger Radio... | Answered on Oct 20, 2015
Ranger TR-696F SSB CB Radio Logo
Popular Tags
10 questions posted
Top Ranger Radio Communications Experts
Steve Allison
Steve Allison
Mike Charette
normis101
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Ranger Radio Communications
Most Popular Question
no modulation
  • Radio Communications
