20 Most Recent
HP Officejet Pro 8000 Wireless InkJet Printer Questions & Answers
How to bypass officejet 8000 out of date cartridge error?
I work with inkjet printers everyday and also with what we call "reman" cartridges. What I have found is that the issues most common can be fixed with another cartridge. If you take a napkin and with the cartridge on your hand make an impression on the napkin, you can tell if the cartridge is dryed up or not. Chances are the cartridges are bad even though they are new to you.
Printer properties cannot be displayed. The print
The printer connected to your Windows computer works with the help of drivers. Drivers are the link between the printer and the Operating System. Problems with some of the drivers (or the printer driver itself) can cause the printer properties cannot be displayed issue. Users facing this problem are suggested to check the drivers installed on the system using Device Manager, and if the printer or any other drivers are found to be incompatible or fake, they will have to be replaced to solve the problem.
HOW do I print on both sides of paper automaticly
First, you need to have the HP Automatic Two-sided Printing Accessory (Duplexer) installed on your printer for it to print double side. If you have it installed, depending on your operating system follow the information on this page: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=au&lc=en&dlc=en&product=3760410&tmp_track_link=ot_search#N242
Using printer on network. Status
Reinstall it! There are some corrupt installation isssues and need a reinstallation.If you need more help post back!
Thumbs and testimonial are welcome!
When I receive an email with an attachment (Word
The spooling process is a natural part of printing files. Usually, if you are sending a number of files to a printer, or, if the file size is large, the spooling time will take longer. Unfortunately, this is unavoidable, unless, you reduce the size of the file(s) first.
The "spooling" process is the transmitting of information to the printer. When there is a lot of information to be sent, the time it takes to print will be longer.
Hope this helps. :)
