20 Most Recent
533 2way Security Remote Start System Questions & Answers
Install manual python 533
I got this free Pdf manual from an online store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the all the times I fixed the chipper in these 4 years
1/30/2019 9:36:40 AM •
533 2way...
Answered
on Jan 30, 2019
How do i program the remote to sync with the car
1/30/2019 9:32:59 AM •
533 2way...
Answered
on Jan 30, 2019
Remote start/alarm works not working properly
First, find the fuse, and sensor to the devise. Pull the fuse and waite a few minutes then replace. Do the same with the sensor, this will clear the devise settings on the cars computer. Then start your car and let it run through the computer system check of all car devises, it will locate the Python devise and resetit. If you have trouble in this process, look your unit up on line and call the tech department and they will walk you through the process. Then go back to Jeffy Lube and have them comp you for their lack of knowing how to work "around" this devise.
5/2/2017 5:41:30 AM •
533 2way...
Answered
on May 02, 2017
Remote start python 533 attempts to start the car, shuts off, then on a again, does it 3 times, then stops
There are three possibilities for the situation you are describing especially if the vehicle has been cold for a while. The first possible cause occurs when the smart tach feature is used. In this case, the 533 is not receiving the proper signal from the vehicle that shows the engine is running. The remedy for this problem is to connect the tach wire from the 533 a proper tach source. The other two causes occur when the smart tach feature is not used and the tach wire is connected. If the tach wire is not connected to a good source for the tach signal in which case the wiring will need to be corrected. Otherwise, the tach signal will need to be relearned.
1/17/2013 4:20:55 AM •
533 2way...
Answered
on Jan 17, 2013
Remote strater is in valet
Try these two possible solutions
Press and hold valet button for 10 seconds. Release. LED should go out.
or
Insert key into ignition. Turn to on position (do not turn on car). Press and hold valet button for 10 seconds. Release. LED should go our
1/4/2011 6:33:25 PM •
533 2way...
Answered
on Jan 04, 2011
How to reset python remote starter
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
Snakes that twist around branches
If you are in the south part of the US, especially if it is around a pecan tree, would suspect it to be a copperhead. At night they like to climb trees and eat insects that also hang out around trees. They blend in very well and starting at dusk, you might want to avoid the base of trees. A rattlesnake also will climb a tree especially if they just ate a rat or something. Have had them drop down on me while walking under a tree.
Chamberlain hbw1573 work with Python 2?
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
How to reset python car starter remote
you can get guide from many sites.. i know few
