20 Most Recent 991 Responder LC3 SST Security/Remote Start System Questions & Answers
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
991 Responder... | Answered on Jan 24, 2019
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
991 Responder... | Answered on Jan 23, 2019
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
very easy just go to reliable-store it has all manuals
there many other websites also but in this matter this website is too good
991 Responder... | Answered on Jan 22, 2019
I located the user guide for your remote...you will need to download the PDF file to view, then search the troubleshooting section...last resort would be to phone the 800 # Customer Care or send the manufacture an email describing your problem...Thanks http://auto.manualsonline.com/manuals/mfg/python/991.html
991 Responder... | Answered on Jan 07, 2016
Most likely your battery. But find your manual in case it needs a reset. Good luck! Karl
991 Responder... | Answered on Jun 10, 2014
hey my name is kristine
991 Responder... | Answered on Dec 05, 2013
The valet switch/programming button is incorporated into the antenna on the windshield.
991 Responder... | Answered on Nov 18, 2013
SOMETHING IS AJAR OR THE CANCEL BUTTON IS BROKEN ON ONE OR MORE OF THE DOORS OR HATCH. SEE THAT EACH ONE IS IN PLACE AND CANCELS THE COURTESY LIGHTS
991 Responder... | Answered on Oct 31, 2013
Okay?
991 Responder... | Answered on Mar 06, 2013
The parking lights will also flash a number of times to inform you of the error. The most common causes of the error are neutral safety shutdown (7 flashes). This is the toggle switch under the dash. Locate said switch and toggle it to the on position. Six flashes is the hood pin switch. Locate the switch under the hood and make the necessary adjustment so the pin makes contact with the hood when the hood is closed.
991 Responder... | Answered on Jan 23, 2013
Do the doors unlock when the remote starter is not running? If so, then you to connect to a different set of door lock wires.I usually connect to the factory alarm and disarm wires in the driver kick panel. They are blue for arm and pink for disarm. You test them by turning the key in the drivers door.
991 Responder... | Answered on Aug 18, 2012
Hello Ihemker,
I understand that you are having a problem with you Python 991 system. The problem is that you front and rear parking lights are not turning off when the alarm is set. Python does not have a suggestion as why this is happening. However, usually resting the system will revert the system to the last good setting.
The system needs to be rest. You can disconnect the car battery for five minutes. The security system has a back up battery that will save the settings of the alarm. If this does not work you will need to take it the a dealer and have them reset the unit.
Thank you for choosing FixYa.com
Justin
991 Responder... | Answered on Apr 01, 2011
The plug of the remote is similiar to many cell phone chargers. They can also be charged with a USB cable connected to a computer.
991 Responder... | Answered on Mar 26, 2011
It is not the "control center" that needs to be switched. The unit itself must be programmed for automatic transmission. The antenna (control center) must be connected to the module for normal operation. Merely connecting the two does not initiate a reaction from the LED. You MUST enter the programming mode (ignition on , ignition off, press and hold programming button until you hear three chirps from the siren). The three chirps are remote starter programming options. After you hear the three chirps, press and release the programming button once then, press and hold the button (you will hear one confirmation chirp), now press and release the lock button on the remote (you should hear two chirps from the system). The unit is now programmed for automatic transmission.
There are several other programming options for your particular vehicle (not mentioned) that may be NECESSARY for the proper operation.
991 Responder... | Answered on Mar 24, 2011
From remote: press F twice on the remote then unlock. (F, F, Unlock) From car: have door open, turn key to ignition position (ON), then OFF, then press and release the button on the control center (antenna on the windshield).
hope this helps.
991 Responder... | Answered on Mar 04, 2011
991 Responder LC3 SST Security/Remote Start System Logo
Popular Tags
45 questions posted
Top Python Vehicle Parts & Accessories Experts
D. E. Hev
Marvin
Marvin
Jesse Garza
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Python Vehicle Parts & Accessories
Most Popular Question
remote start work but door will not
  • Vehicle Parts & Accessories
