20 Most Recent 473P 3-Button TX Remote Questions & Answers
I have a 1998 Chevy Cavalier with a Python 473-P alarm. I want to disable the alarm, any suggestions on how to do this myself?
your old battery may not have been holding its charge I would try with the new one befor disconnecting the alarm if you still wont to disconnect the alarm its not a hard job.
2/22/2014 3:56:56 PM • 473P 3-Button TX... • Answered on Feb 22, 2014
I have the Python 473P remote... the remote is broken, need to replace. But, my Jeep was locked with the remote. I unlocked it with my key and set off the alarm. Now I can not turn off the alarm, n
disconnecting the battery will usually force a reset. you may have to leave it disconnected for a while if it has a backup power supply.
2/8/2014 1:13:35 AM • 473P 3-Button TX... • Answered on Feb 08, 2014
0answers
Manual
Be the first to answer 2/5/2014 11:10:55 PM • 473P 3-Button TX... • Posted on Feb 05, 2014Be the first to answer
Ordered correct replacement remotes for
The sequence is as follows: turn the ignition on, press and release valet switch one time. Press and hold valet switch, press lock button on remote. Release valet switch. Test system.
1/9/2014 1:31:48 AM • 473P 3-Button TX... • Answered on Jan 09, 2014
The keyless lock function does not work,
did you program the wireless key fob into the system?
9/14/2013 3:59:35 AM • 473P 3-Button TX... • Answered on Sep 14, 2013
How can I find a users guide for a Python 473P remote starter?
473P is the part number of the remote. 473P is the original remote for a Python1200XP alarm. I have the users guide.
8/21/2012 1:33:25 AM • 473P 3-Button TX... • Answered on Aug 21, 2012
Remote Starter problem
Sounds like the immoblizer bypass is malfunctioning or, the pellet (resistor) in the ignition key itself is wearing down.
8/14/2012 9:44:47 PM • 473P 3-Button TX... • Answered on Aug 14, 2012
I can only start with the remote. Just bought the car. At 1st I could start it w/o remote.
Sounds like you need a new key cut and programmed to your car.
8/14/2012 11:33:41 AM • 473P 3-Button TX... • Answered on Aug 14, 2012
I bought a Chrysler 300 and it came with a python
We will need the model number of the security unit.
10/19/2011 12:33:28 PM • 473P 3-Button TX... • Answered on Oct 19, 2011
Hope you can help. Older
Sounds like you are in "valet mode". If you can find your model number located on the unit I could be of more help. But, you can try putting the key in the ignition, turn it to the on position, press the valet button located under the dash, in the glove box, or where ever it is located, and then turn the ignition off and you should be out of valet mode.
7/22/2011 6:37:47 PM • 473P 3-Button TX... • Answered on Jul 22, 2011
Put the vehicle in gear while the autostart was
wrong category
2/26/2011 3:04:07 PM • 473P 3-Button TX... • Answered on Feb 26, 2011
Can't get out of valet mode
be sure to leave a door open then turn the ignition on then back off and press the valet switch one time
6/15/2010 7:46:16 PM • 473P 3-Button TX... • Answered on Jun 15, 2010
2answers
How to reset python remote starter
hello u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
12/30/2023 11:50:48 AM • Python Vehicle... • Answered on Dec 30, 2023
3answers
2answers
How do you get the batterie out of a python
Cut it in half and remove the battery it swallowed. The python will likely either bite you or die, however.
4/5/2021 5:48:19 PM • Python Vehicle... • Answered on Apr 05, 2021
473P 3-Button TX Remote Logo
28 questions posted
Top Python Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Python Vehicle Parts & Accessories
Most Popular Question
1998 chevy cavalier python 473 p alarm
  • Vehicle Parts & Accessories
