20 Most Recent
Canon PowerShot A3100 IS Digital Camera Questions & Answers
What is ERROR 32 in below camera ?
Sure it is not error 23? 32 is not on my list, but perhaps I should update that one. For Err 23 stands Too many images. Most of the time the camera can't find space on the memory card for more images. When you only have one card, see what images you can save on a computer, and then delete them from the card.
then check again.
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
What does e32 mean
The E32 error means a hardware or system failure generally not repairable by the user. If you purchased your camera new / retail, it has a full one year warranty from Canon. If this is unsuccessful, you should contact one of the Canon repair contacts for free warranty service using the information provided below.
`i bought a canon Power
Same problem here on a Power Shot A3150 IS with a 8GB micro SD.
All worked well, then bom, only unidentified images. But the camera doesn't tell you unless you review the images...
Tried 5 recovery softwares dso far, some recover the images into a bmp, which then also says unidentified image... Even the camera can't read them.
And if I take a movie, I get an ASCII chaos in the folder the images are recorded in. No solution so far.
Says memory card locked switch
Is you r using a MMC , then there will be a white toggle switch at the bottom side of ur card...just toggle it in other way.....
Shutter speed
Like most point&shoot cameras, the A3100 does not give you direct control over the shutter speed. You're expected to just point the camera and shoot, without worrying about such niggling details.
You can gain some control over the shutter speed by changing the scene mode. For example, portrait mode attempts to reduce the depth of field by opening the aperture, which results in a faster shutter speed. Conversely, landscape mode attempts to increase the depth of field by closing the aperture, which results in a slower shutter speed.
Erro de objetivo apagar automaticamente reiniciar
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Can I retrieve deleted pictures
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos.
This article reviews and outlines several of the better ones:
