20 Most Recent Compaq Presario CQ60-212US Notebook Questions & Answers
My Compaq cannot recognise my Epson TX125 printer. It results in an error in the print Q. I had this on a sony some time ago and PC world fixed it by resetting a parameter on my computer. I was told t
forget Sony this is not SONY at all its HP./MS and Epson. only. lost the epson install disk/? what OS> windows/ what ? XP the CQ60 is very very old PC notebook. and then getting the software from EPSON. matching your OS and the manual to install it is it USB connected, you never said. direct or via external usb hub,(bad) there are many causes. 1: OS corrupted, XP loves to do that 2: XP and vista are now dead, so the driver updates are dead. 2b: that means you must load all the old software by hand. 3: step 2 in the users guide tell you insert CD and install the software. do that, ? re-install all that? i went to epson.com my guess is they do NOT support legacy products they sold at all. not even for XP. print Q (queue) what error,? only this matters now and printer status lamps. does the self test pages work? does the printer status leds show errors, if yes printer its self is bad. ink problems, etc. jams, yes xp has bugs in the queue manager, (tricky to fix, can do) $20 is cheap good rate for help... such a deal ! If more complex it will cost more. if the queue is jammed, only (no errors there) then disconnect the printer. usb cable then click the queue manager and clear the queue out. then start fresh. do a simple short text file first. to see it it works. notepad, edit, hello printer " file , print. the service manual is here free to read. https://www.manualslib.com/products/Epson-Stylus-Tx125-4060230.html
9/1/2017 4:39:32 PM • Compaq Presario... • Answered on Sep 01, 2017
Hello, I have a Compaq CQ60 and have problems
is this a CCFL LDC if yes the inverter is bad. (a card tiny, and thin) its old LT. the books are gone now. the service book tells you how to replace the CCFL inverter find a used good one is problematc. why not buy a newer LT or just run the external screen and be happy I guess you have not read the user guide yet? about the VGA hot key. mine has.: 1: external only 2: internal only 3 both 4: auto. (i think only my newer HP has this) mine is Fn+f4, but on a relic compaq, gee buy the book, or google search for it for weeks, next time post to HP< there is no COMPAQ for years. hp owns it. totally ever seen this before. the fail like LT batteries do. often. http://www.ebay.com/itm/New-15-6-Laptop-Screen-LCD-Inverter-for-Hp-Compaq-G60-G50-CQ50-CQ60-Series-/251312052451?hash=item3a835d98e3:g:ARYAAOSwal5YJoxR search there "compaq CQ60 inverter" bingo. when the sceen is dead do this. see the flash light here, BINGO? bingo for inverter *****? http://pcdied.com/black-screen.html#Dimbulbs
6/27/2017 3:26:45 PM • Compaq Presario... • Answered on Jun 27, 2017
2answers
Compaq CQ60 some keys not working
The keyboard maybe faulty.Connect an external keyboard to youe laptop and if all the key work on this keyboard then most like the laptop keyboard is faulty.If this external keyboard also malfunctions then the keyboard controller chip on the laptop motherboard is faulty and it would not be worth repairing as this is an old model laptop.
11/4/2016 4:41:07 AM • Compaq Presario... • Answered on Nov 04, 2016
My camara on my lap top doze not work after i reset it
Try re-installing the WEBcam driver. You can download the WEBcam and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: - www.compaq.com/country/cpq_support.html
2/13/2013 5:43:32 AM • Compaq Presario... • Answered on Feb 13, 2013
I am unable to turn on the wireless button on my
I am unable to turn on the wireless button on my laptop. It stays glowing orange the whole time and does not turn to blue
9/12/2012 9:01:58 PM • Compaq Presario... • Answered on Sep 12, 2012
The touchpad for myCompaq Presario CQ60 is not working, I have tried forced shutdown and re-boot, the mouse even works in the system recovery menu, but when I re-start, it does not work again, please
Hook an external mouse to the laptop, if yes! do a system restore bringing the computer back to an earlier time before this happened, if the external mouse gives the same problem, do a full system recovery of the operational system if possible for a complete fresh install.
3/9/2012 2:37:45 PM • Compaq Presario... • Answered on Mar 09, 2012
Compaq cq60 keys not working
3/5/2012 5:31:23 AM • Compaq Presario... • Answered on Mar 05, 2012
I am looking for num
Hi
i believe if you do this
press the FN key bottom left along with the nulock which is usually on the top right
so it should be FN+nulock
many thanks
8/18/2011 2:07:21 PM • Compaq Presario... • Answered on Aug 18, 2011
2answers
Hi, I have a laptop compaq
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
7/17/2011 7:41:52 PM • Compaq Presario... • Answered on Jul 17, 2011
When I went to shut it down it had a few programs
Sounds like it is stuck in hibernate mode. Hold the power button down for 5 seconds and try to start it again. If it doesn't start remove the battery, unplug the laptop, hold the power button down for 60 seconds. Now plug in the power supply but leave the battery out. Turn it on. It should start now and you can re-insert the battery.
7/17/2011 6:49:34 PM • Compaq Presario... • Answered on Jul 17, 2011
My computer froze and the
  • Your hard drive has crashed. Your computer was unable to start up because the files needed to start up are missing. You must go to your nearest IT support center (best buy, radio shack) and see if any files from your hard drive can be recovered.
  • Please reply if you have any more questions. Good luck! (Please give a thumbs up, I am doing this for a summer job!)
7/7/2011 4:12:16 AM • Compaq Presario... • Answered on Jul 07, 2011
0answers
My computer was fine this morning and this
Are you able to feel the heat coming up from the system after its turned on?
If yes, there may be problem with the display.
If not, the might be the problem or the underlying hardware would have been faulted.
Please get assistance from the Compaq team on this.
6/18/2011 6:23:00 AM • Compaq Presario... • Answered on Jun 18, 2011
My compaq presario cq60 turns off while shows the
Sounds like a battery problem.
Please refer to the following article for a detailed procedure diagnosing & fixing this issue:
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
6/11/2011 1:30:03 PM • Compaq Presario... • Answered on Jun 11, 2011
I have a Presario CQ60
I'm sure that if you leave it on and don't press the button off that it will stay on the next time you boot up.I've had several different laptops and desktops and they all work the same.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
5/25/2011 3:19:05 AM • Compaq Presario... • Answered on May 25, 2011
I have a Compaq Presario CQ60 with Windows Vista.
check in safemode with networking. if it works, then scan computer for any virus threats. try a sytem restore.
4/23/2011 9:47:56 PM • Compaq Presario... • Answered on Apr 23, 2011
Wireless on my compaq c60
I am unable to find a photo of your laptop's keyboard, so I cannot be certain which function key will enable your wireless adapter.
However, most laptops are very similar, so this solution should work for your problem.
1) Locate the secondary function key (probably labeled "FN") on your keyboard.
2) Locate the key which controls your wireless adapter as a secondary function. It will have the following image on the key: http://cdnsupport.gateway.com/s/Mobile/2007/Phantom/WirelessIcon.gif
3) While holding the FN key, press the wireless key
4) Your wireless adapter is now enabled. If you are still having wireless issues, the problem was not that the hardware wireless adapter was disabled.
4/7/2011 7:30:26 PM • Compaq Presario... • Answered on Apr 07, 2011
Compaq Presario CQ60-212US Notebook Logo
73 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario Compaq
  • Presario Compaq
Most Popular Question
laptop compaq
  • Computers & Internet
