20 Most Recent
Amana DigiSmart PTC153B35AM Thru-Wall/Window Air Conditioner Questions & Answers
O they make a radiator type cover that works for this unit?
Improve the FixYa experience for everyone by voting.Hi,If you are interested, Just Cover It Up has just come to my attention and they have the widest selection around. Their claim to fame is: Air Conditioner Covers for Central, Window, and Wall Units.
CLICK HEREI have no personal interest or association with any product that I may suggest.
Work in a hotel and I have some broken front
Sir, we don't and can't sell anything on this website, other than information on how to repair something or where YOU can find it. In this case, I would suggest that you contact the manufacturer, Amana directly.
Amana PTAC (PTC153B35AM).
Unit has simply
The hum that you arehearing is probably the transformer so that is working...as far as what the problem is...
that could be many different things...
The control board just went bad....
the keypad is bad....
A sensor is bad...
Dip switches positioned wrong...
Is there an external t-stat???
To find the exact problem it will take an experience tech. with an electric meter to follow things through and figure out what is going on there...
heatman101
I'm not getting any code after installing a control board for my Amana ptac?
Does the power light come on?
If yes, then you can do a reset as below:
There is a master switch on the bottom left of the control board. Slide that to 'off' position.
Then press the hot and cold switch/key together and then slide the master switch back to 'on'.
Please put your response/observation here if that does not work or there is power light as asked on top.
Thanks
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
Amana Wall unit blows cold air before heating
The cold that you describe may be just unconditioned air? If you are certain you can hear the comp operating for a couple of minutes, and then the heat starts, I would guess it is a reversing valve issue if it's a heat pump and it probably is. Or the control board acting up. I've had a lot of issues with the boards in the Amanda PTAC units. I can't remember how to configure it, but if you Google "Amanda ptac configuration", there is a lot of info online. May try a reset method first. Hope this helps!
