20 Most Recent
Amana PTC153B35AJ Air Conditioner Questions & Answers
Heat won't come on
If it is a reverse cycle unit the magnetic reverse cycle switch is faulty and should be replaced
5/16/2014 4:43:27 AM •
Amana...
Answered
on May 16, 2014
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
7/3/2013 2:07:57 AM •
Amana...
Answered
on Jul 03, 2013
What does diagnostic code lf mean
1blink/sec---normal, 2blink/sec--blown fuse--3bliks/sec--replace evaporator sensor,4blinks/sec--mode switch failure, replace board,5blinks/sec--pot. failure,replace board;6blinks/sec--bad thermostat input; 7blinks/sec--factory only;8blinks/sec--bad room thermostat. The blink pattern repeats every 5 seconds.
2/2/2013 3:43:24 AM •
Amana...
Answered
on Feb 02, 2013
