20 Most Recent
Lutron Dim-N-Glo Push On/Off Dimmer Questions & Answers
Lutron Dimmer - Maestro Desert Stone color is discontinued
You're in a difficult position for which I see few options --- none of them ideal. Short of replacing all your switches and wall plates in a matching color of your choice, a cheaper option might be to find a satin spray paint in or near-enough to your color and gently spraying the new dimmer(s) to match.
Alternatively, Eaton makes LED dimmers in "Desert Sand" (but whether their Desert Sand looks anything like Lutron's is beyond me).
5/17/2023 9:34:50 PM •
Lutron...
Answered
on May 17, 2023
Yellow jumper wire
The directions tell you where to connect it. My eyes are poor and I cannot see what you have!
10/2/2021 3:13:53 AM •
Lutron...
Answered
on Oct 02, 2021
How do I fix my light switch? I checked my circuit breaker and that's working. I replaced the switch with a new switch and it still doesn't work.
You might look to see if the outlet is GFI protected. It is possible the GFI (Ground Fault Interrupter) tripped and needs to be reset.
If so, push the red button (reset button) firmly until it stays down (pushed in). If it does not stay closed, replace it.
Also check your light bulb fed by "the switch that does not work", to make sure it did not burn out.
Your switch could be good, but the bulb bad.
If your light switch is not on a GFI circuit and both Lutron switches are fed by one breaker, get a volt-ohm meter, set it to the volts in a voltage range to read house hold voltage (around 121 volts), and check to see that both switches are receiving 121 volts. Usually you measure with the black probe touching a white (neutral) wire, while the black wire is usually the wire that is in series with the lamp. A black wire may come into the switch and leave as a black wire going to the bulb. If you do not have full voltage reaching your switch, you may have a wiring problem where a wire is no longer making good contact. If you are not sure about how to test with a volt meter, search on your tube for further explanations on how to test to see if a light switch is good.
12/31/2018 6:23:00 AM •
Lutron...
Answered
on Dec 31, 2018
First, I have power running thru a switch box. All
Let's start at the beginning please. You have a source cable fed into an overhead outlet box or to a switch outlet box on the wall? This is critical because it tells me what kind of arrangement you actually have.
If the source is in the ceiling, then you are using switch loops and the wiring gets tricky because you have to "re-task" the Neutral (White) wire (Assuming you are here in the U.S.A.) that goes to the switch because it will become the feed to the wall switch.
However, is the feed is at the switch, then it is much simpler. Please let me know what you have in the form of wiring.
Also as an FYI, if you are using special switches, you may have to have equipment grounding conductor present at the switch. The electrical code no longer allows the use of a Neutral (White) conductor as a grounding conductor.
11/27/2017 6:41:36 PM •
Lutron...
Answered
on Nov 27, 2017
