20 Most Recent Lutron #D-600PH-DK 600W SP Push Rotating Dimmer Questions & Answers
General info.. Power to gold screw. Fixture to silver screw. Black screw to black screw on each switch.
Lutron... | Answered on Dec 13, 2013
We are truly sorry for your inconvenience and want to help. Please call our Technical Support line at 1-888-523-9466 and we'll be happy to discuss the issues with you.
Craig, Lutron Technical Support Leader
Lutron... | Answered on Nov 29, 2012
Hi -
The Lutron D600P is a preset single pole dimmer. Wiring is pretty straight forward as show in this diagram. Recheck wiring and if OK, continue below.
If power is present on both wires (black / red wires), power is being passed through the switch to the lamp and the light should be on. If not, try replacing the lamp.
Minimum recommended connected load is 40 watts. This switch is ONLY for use with filament type lamps - such as traditional tungsten, halogen, etc. It is NOT to control speed of Fan Motors, nor dimming of CFL (compact fluorescent lamps) energy saving types or other ballast operated lamps such as High (or Low) Pressure Sodium, Metal Halide, Fluorescent, etc. as this would create a high heat condition and could cause a fire.
If you're still having trouble, you can contact Lutron Technical Support Center 1.800.523.9466 24 hrs / 7 days www.lutron.com
I hope this helps & good luck!
Lutron... | Answered on Sep 04, 2012
As a general rule, grounding will not affect operation of dimmer.
Type of dimmer, type of switch being replaced, type of load, and how you connect wires will affect dimmer.
Here is Lutron dimmer switch page
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
What is the load? Are you wiring dimmer to a ballast? Or fan? Or incandescent lights? Or florescent lights?
Are you replacing a 2-way or 3-way switch?
What color are your dimmer wires?
How many wires were connected to switch?
Can you re-install the switch, and know where each wire went?
Did you replace a light with a fan, and then want the dimmer to slow the fan? Not every dimmer will work with a fan, or florescent lights.
Dimmers cannot dim LED lights.
If I know what type switch you are replacing, and the type of load you want to control, and the specific dimmer you have, I can answer the question.
Lutron... | Answered on Oct 12, 2010
Place it under the mounting plate where the 2 mounting screws mount to the wall box.
Lutron... | Answered on Feb 20, 2010
Unfortunately, the hum is normal for operation of that type of dimmer at low levels.  Sometimes the lamp filaments will also "sing" a high pitched sound.
Lutron... | Answered on Jun 02, 2009
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Lutron... | Answered on Mar 17, 2009
It's not the dimmer causing the problem it's the bulbs. They are like mini florescent lights and are not dimable. You will need to either change them to regular incandescent lights or purchase the dimable type of energy efficient bulbs. They are a bit pricey but they will work. Let me know and don't forget to rate me. Thanks
Lutron... | Answered on Dec 19, 2008
You may want to consider getting an "electronic" dimmer vs. a manual knob or slider. Consider using a Maestro (MA-600-XX where XX is the color). The Maestro fits into a decora opening so you may also want to get a new wallplate (Lutron makes these in a screwless version: CW-1-XX where XX is the color).
Hope this helps.
Lutron... | Answered on Oct 17, 2008
I take it you don't want to just remove the upstairs 3 way switch and wirenut the 3 wires together and put a blank cover plate over the box<?>.
Need to know more info. Does the upstairs box have 3 wires only? If no, then likely you will not be able to abandon the upstairs switch box as it will need to remain as an active junction box. If yes, then it becomes a rather lengthy procedure (textual). I'll sketch it out but need an answer the number of wires in upstairs box.
Comment below so I may assist further.
Lutron... | Answered on Apr 11, 2019
There are a lot of DIVA models and you did not post the model number. There are multple configurations and wiring methods.
Lutron... | Answered on Feb 09, 2019
You might look to see if the outlet is GFI protected. It is possible the GFI (Ground Fault Interrupter) tripped and needs to be reset.
If so, push the red button (reset button) firmly until it stays down (pushed in). If it does not stay closed, replace it.
Also check your light bulb fed by "the switch that does not work", to make sure it did not burn out.
Your switch could be good, but the bulb bad.
If your light switch is not on a GFI circuit and both Lutron switches are fed by one breaker, get a volt-ohm meter, set it to the volts in a voltage range to read house hold voltage (around 121 volts), and check to see that both switches are receiving 121 volts. Usually you measure with the black probe touching a white (neutral) wire, while the black wire is usually the wire that is in series with the lamp. A black wire may come into the switch and leave as a black wire going to the bulb. If you do not have full voltage reaching your switch, you may have a wiring problem where a wire is no longer making good contact. If you are not sure about how to test with a volt meter, search on your tube for further explanations on how to test to see if a light switch is good.
Lutron... | Answered on Dec 31, 2018
Not sure if you can just splice the extra wires together. The ballast information is what matters converting to just on-off, not the finger switchswitch
Lutron... | Answered on Dec 01, 2018
Let's start at the beginning please. You have a source cable fed into an overhead outlet box or to a switch outlet box on the wall? This is critical because it tells me what kind of arrangement you actually have.
If the source is in the ceiling, then you are using switch loops and the wiring gets tricky because you have to "re-task" the Neutral (White) wire (Assuming you are here in the U.S.A.) that goes to the switch because it will become the feed to the wall switch.
However, is the feed is at the switch, then it is much simpler. Please let me know what you have in the form of wiring.
Also as an FYI, if you are using special switches, you may have to have equipment grounding conductor present at the switch. The electrical code no longer allows the use of a Neutral (White) conductor as a grounding conductor.
Lutron... | Answered on Nov 27, 2017
You could do that but it would not be up to the electrical code requirements. Take the old one out and remove the wire nuts and put the new one in. There should be a ground wire stuffed in the box somewhere. Unless the house is really old. You connect the ground wire to the bare ones in the box.
Lutron... | Answered on Nov 21, 2016
Lutron #D-600PH-DK 600W SP Push Rotating Dimmer Logo
Popular Tags
12 questions posted
Top Lutron Electrical Supplies Experts
Craig Butler
Craig Butler
mikenearman
Thomas F. Schneider
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lutron Electrical Supplies
Most Popular Question
no ground wire
  • Electrical Supplies
