http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da1) Uses one 24-pin ATX main power cable.Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector. (Right side of motherboard)General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain242) Uses one 4-pin ATX +12 Volt power cable,Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4THAT, would be considered a Power Supply diagram of the motherboard.They are the only two power cables that plug into the motherboard.The front of your desktop computer is the Front Panel.The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.Regards,joecoolvette
