If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker. volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume.
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable).
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit. Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for.
Tick in either the all software or windows software box
IE: motherboard name audio driver you might have to try a few times to get it right
if you dont have a disk with the drivers you will have to download them
using this link you will be able select your drivers http://download.cnet.com/driver-complete-rar/3000-2112_4-210081.html http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html if these arent right you will find free sound drivers http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for ie:intel laptop (be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps
43 questions posted
46 Questions
42 Questions
36 Questions
26 Questions
24 Questions
