20 Most Recent
ECS 945P-A (V3.0) Motherboard Questions & Answers
.ECS 945P-A (V3.0)
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=672&MenuID=16&LanID=0
Ecs service center
go to ecs web site then contact us at the bottom of page it will show you.
Service center delhi
remove as much dust from the insides as possible and if you have overclocked, reset the BIOS settings by removing the CMOS battery on the system board for about two minutes.
Sir/ma'ms i need ecs rs482m-m
Download here:http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=536&DetailName=Feature&MenuID=24&LanID=0This link works.Good luck
Video card for 945p-a v3.0
Hello you can read all about the mainboard here:http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=672&CategoryID=1&MenuID=16&LanID=0It should be compatibel with PCI-EGood luck
I need driver motherbord 945pt-a2/1333
which device driver ? are you looking for i am unable to find it for you if i dont know which device it is
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)except numbers and ) / _ also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
if you need more help finding the device driver post a reply with the device
hope this helps you
I started having problem with
Try resetting bios. This is done by a small jumper on most modern boards. location on your board. Try resetting bios. This is done by a small jumper on most modern boards. See image for the location on your model. Simply take the jumper (it is the plastic piece on two metal prongs. Move it so that it is on the middle and opposite prongs. to be sure of the reset start and after a 5 count turn off your pc. Move the jumper to its original position. This should allow you access to bios.
Hi there. I have a
Check herehttp://www.google.co.in/url?sa=t&source=web&cd=1&ved=0CBYQFjAA&url=http%3A%2F%2Fwww.ecs.com.tw%2FECSWebSite_2007%2FDownloads%2FProductsDetail_Download.aspx%3Fdetailid%3D525%26DetailName%3DNew%26DetailDesc%3D945P-A%2520%2520(V1.1)%26CategoryID%3D1%26MenuID%3D82%26LanID%3D0&ei=02jpTJKoPIa8vwPjuMmhBA&usg=AFQjCNHNGJKr5YpD7dcdNC0vSmy2IGDwkA&sig2=-J3toMmAn9yb2J4yfCR3ZgRate my answer and Support me
