SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
SOURCE: Last night the cooker rcd tripped. On resetting,
SOUNDS LIKE YOUR BOTTOM HEATING ELEMENT HAS BURNT OUT AND IS PROBLEY CAUSING A TRIP.
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
SOURCE: Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
